3.6L ESS Aux Battery Bypass
Jebiruph
Jebiruph
Jerry
Iowa
2018 JLU, 2019 KL, 2020 JT
Rufus
NYC
2018 2 door JL Sport 3.6 V6
In case some of you are not aware, this link is to a thread where I try to answer all the questions and I try to add all the new information to the first two threads. https://www.jlwranglerforums.com/forum/threads/3-6l-ess-dual-battery-consolidated-information.25377/
First, thank you for all of your research in to this and for posting the info. I did go through the above thread previously. My question is, is the below section from the above thread the same thing as the N1-N2 jumper described in the beginning of this thread?
Bypassing the Aux Battery
A bad or discharged aux battery can affect PCR operation, which can be disruptive to system electronics and it may need to be bypassed. Bypassing can be accomplished by using a (fused) jumper wire to connect the main battery directly to the system electronics at PDC terminal N1 or by unplugging the PCR, preventing it from disrupting the system electronics.
Jebiruph
Jebiruph
Jerry
Iowa
Yes it is. The main battery is connected to directly to N2, so connecting the fused jumper from N2 to N1 or from the main battery positive to N1 is the same.
Rufus
NYC
Thanks!
Midwestguy
J
Minnesota
None
Odd request, but can someone tell me what size (thread?) the wingnuts are to secure the terminals to the N1/N2 posts? Im making up a kit for a few jeeps as backups for this winter....
Rufus
NYC
I recently asked the same question over on the thread about nuts and bolts sizes. No response yet.
Also would a wing nut have the room between posts to be spun between posts?
I was also thinking about small clamps for the jumper I’m going to make.
Midwestguy
J
Minnesota
None
Midwestguy
J
Minnesota
None
I do know that a wingnut thats close in size/thread works as I tried it out with one thats close and theres enough clearance
Jebiruph
Jebiruph
Jerry
Iowa
N1, N2 and main baterry negative are M6x1.0
Aux battery negative is M8x1.25
Some have bought wingnuts that were too wide. All the ones I bought fit between the post, but you may have to back the first one off a little until the second one is on.
HoundDude
New Jersey (i know, i know, i'm stuck here)
2019 Wrangler JL Sahara
I created two auxillary bypass fused jumpers today (similar to jumper in first post). I used a crimping tool (link below) to install a ring terminal connector on each end. the connection feels pretty solid.
question: should I also use a soldering iron to apply solder to the ring connector/wire end? normally I would just do this without thinking about it but thought I'd check here first, thanks!
crimping tool:
https://www.amazon.com/gp/product/B0069TRKJ0/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
GRAK
Out West
JL Rubi, Corvette
So uh I've got the little wire with the fuse on it in the glovebox just in case... say it won't start out in the middle of nowhere... I just loop it over posts 1 & 2, no special order, no disconnecting anything first, won't zap myself dead? Just confirming :LOL:
cbrenthus
FL
'19 Mojito JLUR
So wait, after playing around with this I've learned that the batteries are in parallel when the engine is off. You can disconnect the Aux battery simply by removing the negative terminal, and the Jeep still starts but gives you an ESS error. So why would anyone install the jumper to jump start rather than just disconnect the AUX?
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
I have looped N1 and N2 with a fused jumper and then removed the ESS negative off the main and my JL has started and ran fine with no error messages, I left it that way for just over a week and all was good, was going to leave it permanent but it’s under warranty so I just carry the jumper
c2m2h3
US
2012 JKU Wrangler Sahara
When you say ESS negative, are you referring to the Aux Battery negative ?
WranglerMan
Will
Katy Texas
Gas Pipeliner
When I say ESS negative I am referring to the ESS negative that is connected to the main battery negative.
