Rubi
- David
- Dec 25, 2016
- Connecticut
- ā18 Jeep JLR
Excellent procedure; the most simplest route is always the best. If I disconnect the hood open switch, to disable ESS, will there be any related problems other than the dash warning light?I completely removed the auxiliary battery and wiring about 2 weeks ago due to a bad aux battery but learned something important if you do it this way. A 30 amp fuse is not enough to carry the max load of everything powered by the N1 terminal and when that fuse blows under those conditions it definitely lets you down and you don't have emergency flashers, windows won't roll up and down, etc. I did an amperage check and I was seeing 30.9 amps with heater blower at full blast and radio at about half volume, so I came off of N3 which originally fed the aux battery and is fused at 150A and ran a 6 gauge jumper to N1, I feel more comfortable doing it that way instead of a jumper from N2 to N1 which would have no fusing and could carry whatever current the main battery could provide.
