3.6L ESS Aux Battery Bypass
Jebiruph
Jebiruph
Jerry
Iowa
2018 JLU, 2000 TJ, 2019 Kl, 2020 JT, 2018 BU
  • Thread starter
  • Thread Starter
  • #61
Just completed two weeks with the Aux battery bypassed. No difference in the operation of the jeep, I actually forgot it was bypassed. Bypassing hasn't changed the running voltage, still running around 14.7 v.
WranglerMan
Will
Katy Texas
2018 Wrangler JLU Sahara
Gas Pipeliner
Seems it hit and miss on the voltages running high, some say 14+ all the time and others like me reporting voltages are between 12.6-14 depending on what’s going on, super glad to hear your bypass invention has worked without issues, so do you use a programmer like a Tazer or Flashcal and do you use ESS
Rubi
Connecticut
‘18 Jeep JLR, Porsche
I’m curiously waiting for you to take the momentous leap and completely remove the auxiliary battery from your vehicle.
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #64
No programmer and I intend to always disable ESS, but the times I forget, it always works as designed.
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #65
I don't have any plans to physically remove it, but with the ground cable disconnected there is no electricity flowing through it, so it is electrically removed. It does provide a benefit when it works, so as long as I can bypass it when it doesn't, it will stay in unless I install a real dual battery system.
Rubi
Connecticut
I’m interested in making it more simple. Do we really know how long this aux battery will last and what it will cost for replacement? As everyone knows a standard automotive battery lasts at least 5 years with a simple replacement procedure. From what I’ve seen from other auto manufacturers, aux batteries only last about 2 years, can’t be easily purchased only through dealers and are very expensive.
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #67
You don't have to rely on the experience of other auto manufacturers, FCA already had this system in place on other vehicles, check out some of those forums. I looked up the PCR part number (56029766AC) and then referenced which vehicles used the part. I got the most information on a Pacifica forum. Let's just say I don't have much hope things will improve.
WranglerMan
Will
Katy Texas
Gas Pipeliner
@Jebiruph I’m thinking when my ESS battery takes a crap outside of warranty I’m thinking just bypass it as you have with the bypass cable kit you invented and just use the main battery
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #69
Don't wait until it goes bad to bypass it, if you're going to do it, bypass it while it is still good. Then if your main battery is not able crank the starter, you have a functional backup available.
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #70
I will suggest that the ESS battery issues probably haven't been as big of an issue on the other vehicles as they are on the Wrangler because the other vehicles are less likely to get stranded out in the middle of nowhere.
Rubi
Connecticut
To enlighten us all with this knowledge, do you know how long the aux battery lasts and what is its replacement cost?
Jebiruph
Jebiruph
Jerry
Iowa
  • Thread starter
  • Thread Starter
  • #72
According to my notes, somebody posted a battery part number of BBAUA200AD, which I see priced around $120. As far as battery life, everything I have read is anecdotal, so no set time for how long it lasts. But based on posts in related forums, other vehicles seem to have similar failures. You would have to read them for yourself and make your own conclusion.
WranglerMan
Will
Katy Texas
Gas Pipeliner
For me it’s not so much the cost or using tools to put it in it’s the hassle it will be getting to it, like I have said FCA did a terrible job in placement of this ESS battery
Rubi
Connecticut
I’m wondering/hoping that the ESS hood switch deactivation will allow a maximum lifespan for this aux battery. Also if this battery does fail will you still be able to start and drive the Jeep?
WranglerMan
Will
Katy Texas
Gas Pipeliner
Well if your wondering if the aux battery fails will you still be able to drive your JL you need to catchup on the battery bypass invention that @Jebiruph created, he ran with this bypass on for several weeks I believe and the ESS battery was disconnected and I don’t believe he had any issues.
