- Andy
- Nov 19, 2019
- SanFrancisco
- JL Wrangler
- Banned
- #406
I do! I can't remember if the nut is 13mm but yes. Restated it is the factory cable (1 of 2) CLOSER to the passenger's front quarter panel. The more distal cable on the main battery's negative terminal to the front passenger's quarter panel is, at its other end tied into the grounding point on the passenger's front quarter panel.So to confirm,
you mean remove the negative cable with a 13mm nut going to the main batteries’ negative post, and then connect my tester to it and the other end of the tester to the untouched positive on the main?
the way I did it in the photo was I just completely disconnected the main battery and then performed the test as “in vehicle” with the two disconnected connectors.
Maybe a narrative of why this works is indicated here.
Touch the tester to the positive terminal of the main battery will then provide the voltage to any circuit connected to that main battery terminal based on where you are about to place that negative tester terminal.
Were you to place the tester's negative side on the main battery's negative post, (and the cable discussed above is removed from the main battery's negative terminal) you'd get the main battery's voltage.
But if you were to put the negative side of the battery tester on the aforementioned dangling wire that you took off the main battery, which directly connects to the ESS/Aux battery's negative post, you would get the voltage of only the ESS/Aux battery.
If everything were hooked up as the factory provided the vehicle and you put your tester on the main battery terminals you would get a composite voltage of both batteries.
Testers read only complete circuits, agreed? Agreed.
Just such a circuit exists on the ESS/Aux battery, and only the ESS/Aux battery because there is a clean uninterrupted flow of electrons from the main battery's positive terminal (in the 3.6L JL) to
* terminal N2 in the Power Distribution Center (PDC),
* which is directly connected to neighboring N1 in the PDC at all times (including with the engine off and the rig parked) but an instant during an engine crank (on a 3.6L JL) and during ESS events....
(or hard connected to N1 at all times if you use Jerry's jumper......)
(Jerry's jumper can be between N1 and N2 or the main battery's positive terminal (which is hard wired to N2) and N1---it doesn't matter)
* and the cable off of N1 connects directly and uninterrupted to the positive terminal of the ESS/Aux battery,
* which connects internally in the ESS/Aux battery to the negative post of the ESS/Aux battery,
* which has a direct and uninterrupted cable coming off it to the main battery's negative post
* which you have disconnected from the main battery by design, preventing the main battery from being part of the circuit
* to which the negative prongs of your tester are attached...
Don't forget to reattach that cable back to the main battery's negative post when done with your testing.
Rob---if you have the time, this is an excellent read, where Jerry, who I learned much of this from, sets up a system where he can take voltages of neither, both, or just 1 of the 2 batteries by merely flipping some switches he includes in his setup. Some the very principles above apply.
https://www.jlwranglerforums.com/forum/threads/ess-dual-battery-management.60034/
