conFUcius
- Stephen
- Jul 10, 2020
- North Carolina
- 2020 Sting-Gray JLU Rubicon 3.6 V6
- Occupation
- Medical Affairs
The questions I have for those with 3.6L engine, automatic transmission, and 37” tires:
I care about having 8th gear back on the highway. My off-roading is usually crawling on rocks, not slogging through mud or blasting through the desert over dunes.
- Did you regear to 4.88 or 5.13 gears?
- Do you regret your choice and wish you’d selected another ratio?
- What do you like most and least about your new gear ratio?
- Anything in hindsight that you wish you’d known beforehand?
- 5.13s
- No regrets so far. The pinion is a lot smaller but I will just keep that in mind when wheeling to be mindful of that weak point.
- Acceleration around town is decent (I fully acknowledge the Wrangler is not for speed but that doesn’t stop me from desiring it off the line); even with the addition of a steel bumper/winch, still does fine. Highway cruising (70 to 80 MPH) is much smoother since it will stay in 8th and not jump all over the place. The one ‘con’ I could name is fuel economy since I averaged 18 to 20 MPG before and now I’m pretty much around 15 MPG (+/-). Without getting political, this is something one should keep in mind as gas prices rise. Even if money and MPG is not important to you, the frequency in which you have to stop and fill up is an inconvenience too.
- This is less from having the JLU and more from when I had a 6-speed JKU. Know what your final tire size will end up being. I got re-geared in the JKU from 3.73 to 4.56 and was happy with 35s but then I went to 37s and hated being under-geared. Ended up selling it for other reasons but I was basically having to entertain a second re-gear. No one I know said they felt over-geared at any point but there’s anecdotal accounts of people desiring a shorter (numerically higher) gear ratio than they currently have.
Good luck with your decision!
