Remorseless
- May 10, 2022
- NC
- '22 JLR 2.0T, '24 JTR, '19 Charger R/T
- Build Thread
- Link
- Occupation
- Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Guy Who Defines What A Jeep Guy Is
lol, how can I have confirmation bias when I currently choose to own both engines? I own both, right now, and willingly chose both. There isn't some "I chose this one I want it to win!", since I chose both. It wasn't a begrudging choice of the 3.6 either, I'm fine with the engine. It just does struggle enough with the weight of modern Jeeps that it is night and day between the two for feel. I would argue that having both in my current stable makes the argument more valid as I have direct back to back comparisons. In fact, if anything, I went into the 2.0T with trepidation - I wanted to try something new, but I wasn't sure if a turbo 4 banger was going to suck or not. Just turns out it doesn't.I don't notice a difference between the 4.10s and 4.56s on either the 3.6 or 2.0. I noticed a BIG difference between the 3.45s and 4.10s though, for both engines, especially on 35s. The jump to 4.10s completely transformed the experience. But then going to 4.56 did not further improve said experience.
I will call BS anytime someone tries to say that the power difference between the two engines is "night and day". That's confirmation bias, just trying to re-assure oneself that they made the right choice. There just is not much difference. The 3.6 has a bit more "jump" off the line, and the 2.0 has a bit more when you jump out to pass at speed. That's it.
With my 3.6, I'm constantly having to tip in to get it to kick down a gear or two to maintain speed. I don't drive hard - it's a box on wheels, just chill and cruise, plus I've usually got the kids with me in the truck. Coming off from a stop it's one of those things where you're urging the truck to get up to speed when using reasonable throttle inputs and it's just not quite moving as fast as you expect for the amount of throttle. No such issues with the 2.0, despite turning much larger and heavier tires. AND with the weight of the tires and stuff, I'd wager I'm within a couple hundred pounds of the JT with the JL anyway.
