3.6 likes to leak
D60
CO
JL
I've got at least three oil leaks on my '19: the upper oil pan near the front, the RH valve cover and somewhere else underneath either behind the exhaust manifold or near the LH head.
Nice work FCA, what other vehicle has this many leaks at 27k?
I'm going to take it to dealer and hope they'll warranty it.
JLJeepGuy513
Ivan
2018 JLUS, 2016 Pathfinder
Civil Engineering Designer
I'm here joining the leak group! i cant really find where its coming from though. i saw it when i went to install a new driveshaft. It must have just happened because it wasnt there last week. its dripping from trans bell housing but cant seem to follow it up to where its coming from. I dont think its the RMS. I also went to check the filter housing but no oil there either. I did however find that alternator pulley is shooting grease everywhere also. i'm at 41,000 miles.
blnewt
New Mexico
Just ask @cosine he knows!
My rear main is leaking just a bit, hasn't gotten noticeably worse over the last 8 mos since first noticed it. If it gets to be an issue I'll probably just do the repair myself as I don't trust the local dealer to change my oil filter :(
SPR Pumpkin Rubi
Tripp
Hoschton, Ga
skinny-pedal-racing.myshopify.com
18' JLUR, 04 TJ 1-Ton LS, 4400 U4
Sell Jeep Parts
This was mine, and it ended up being the plastic oil filter housing. I thought it was the rear main at first but jeep said it was the oil filter housing. Replaced under warranty without issue, but seems to be a common issue, especially with the JK from reading.
intentsrig
JLU Sporticon
Definitely be careful of over tightening the oil filter into the housing causing it to crack. Not always the issue but it'll drip everywhere and look worse than it is.
blnewt
New Mexico
So your rubber oil plugs at the bell housing were oily and oozing? Maybe I'll get lucky and that's what's going on w/ mine. Is yours staying dry under there now?
Rodeoflyer
Bert
Conifer, Colorado
zrickety
Technician
My filter came with paint marks from the factory that show the proper torque. I have loosened and reinstalled 3 times so far without issue.
zrickety
Technician
jlewissystem
J
STL
2019 JLUR MANUAL Mojito!
Took mine in today - 27K on it. Leaking at bell housing - i'm assuming rear main seal. Will post back.
Rodeoflyer
Bert
Conifer, Colorado
Interesting they list that for the JK but not the JL.
I'd assume it's the same part but will cross that bridge when I come to it. I do my own fluid changes and have known about that fragile plastic housing so I'm careful about gently torqueing the filter on. It wouldn't surprise me if the oil change places use an air tool lol.
jlewissystem
J
STL
Confirmed - rear main seal at 27K. Sheesh....
