- Matt
- Oct 16, 2016
- CA
- Website
- www.gorancho.com
- 2013 JKU
3.5" is for the Rubicon
4.5" is for the non-Rubcion
The NEW Crawler Short Arm Systems are the result of continuous improvements done by Rancho® to give you the best possible on and off-road experience for your JL Wrangler. These kits include corner specific progressive rate coil springs and fully adjustable control arms (adjustable on the vehicle!) with D2 bushings to give you improved comfort, durability and worry free operation. They also feature our NEW heavy-duty front and rear adjustable track bars with D2 bushings to center the axles. The D2 bushings found in our control arms and track bars feature PTFE for grease-free operation allowing the sleeve to rotate in the bushing without resistance reducing wear. Precise adjustments can be made while it’s still installed on the vehicle. Pair with the Rancho JL-specific shocks that feature our Dynamic Rebound Spring (DRS) Technology. This DRS Technology features a precisely tuned metal spring that provides additional control, reduces body roll, and prevents overextension. Choose from either the RS5000X or the adjustable RS9000XL.
- Premium on and off-road experience for your JL Wrangler
- Corner-Specific, Tuned progressive rate coil spring
- On vehicle adjustable control arms with D2 bushings
- Heavy-duty front and rear adjustable track bars with D2 bushings
- All brackets fabricated from high-strength, low-alloy steel
- Designed with 37-in. tires
- Installs easily - 100-Percent bolt-on system
