3.0D What’s your hand calculated DIESEL mileage?
SecondTJ
Il
Jeep
It will be slightly different. Use this link to type in your own numbers. http://www.grimmjeeper.com/gears.html
play around with it
these are the ZF 8HP75 transmission numbers.
Ratio 1= 5.0000 2= 3.2000 3= 2.1429 4= 1.7200 5= 1.3139 6= 1.0000 7= 0.8221 8= 0.6400 Rev= 3.4560
stock @ 70 MPH would turn 1701 RPM
37's on 4.10's @ 70 MPH would turn 1688 RPM
Those are the wrong gear ratios. Not a big difference but here are the correct ones:
1st: 4.714
2nd: 3.143
3rd: 2.106
4th: 1.667
5th: 1.285
6th: 1.000
7th: 0.839
8th: 0.667
JTRdiesel
Canada
Colorado ZR2
1st: 4.714
2nd: 3.143
3rd: 2.106
4th: 1.667
5th: 1.285
6th: 1.000
7th: 0.839
8th: 0.667
actually those are the ratios for the 8hp70 in that was behind the previous generation of EcoDiesel in the grand Cherokee and ram 1500. The ratios Motoristx stated are the correct values.
SecondTJ
Il
Jeep
It has not changed. FCA uses the same forward gear ratio set on 8HP75 as the 850RE, 8HP70 and even 8HP90
JTRdiesel
Canada
Colorado ZR2
Anyone able to tell me what your RPMs are stock at 70mph? @SecondTJ ive got conflicting pieces of information from various sources including FCAs euro and North American websites, my Jeep still hasn’t arrived yet so I can’t confirm myself.
SecondTJ
Il
Jeep
WVB
Wes
Arvada, CO
2020 Willys Unlimited 3.0L Diesel HellaYella
Two tanks. 1st was 24.5.(40/60 hwy/city) 2nd was 27.2 (70/30). All stock for now.
Computer showed almost exactly 2mpg better than the real numbers
purple haze
Massachusetts
2020 JLU Ecodiesel Sport Altitude
First tank 29 on the dash and 29.7 calculated driving mostly highway. Thats with me taking it easy and going the speed limit. Second tank dash is reading 31.3 with half a tank left. Anyone else notice the trans shifting too early into second gear.
No Spark V6
Chicago NW burbs
2021 Rubi 3.0 GCM
1700 miles on the odometer, avg 26-27 mpg, used a little less than 1/4 tank of DEF. Assuming the gauge is accurate and linear(not holding my breath), I'm pretty happy.
rickinAZ
Phoenix
I must be heavy-footed. I have 800+ miles on 35s and my average is in the 19s. Almost all in-town miles. They say that elections have consequences. I say that access to all of that torque has consequences as well. :)
BTW the 19s are 6 mpg better than my JK on 35s in the same driving conditions.
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
This is the sort of comparison which is vastly more useful than the standard nonsense about the monroney mpg vs actual when most of us heavily modify these things and stuff the skinny pedal frequently because it’s great fun. Your 40% increase in mpg compared to a JK similarly outfitted and in the same driving conditions computes with the 35% increase I’ve seen between my ‘18 JLUR 3.6 and ‘20 JLUR 3.0 with the former on 33s and 35s and the latter on 35s and 37s.
KevinD
Inland Northwest
2021 Gladiator
Been doing it for years on my JLUR, wife’s compass and two prior VW diesels without issue...have you run into this problem?
I've had two different cars have issues: a Ford & a Mercedes.
It's a real PITA when you can't even run the pump on the first notch without it clicking off. Takes FOREVER to get a fill.
And yes, the problem was verified by the dealer, as having come from overfilling. Too expensive to have it corrected on the Mercedes, and I simply got rid of the Ford.
