3.0 won’t crank
hazards280
Midland MI
2020 JLU Willys - 3.0L Diesel
It's very likely your fuel is gelled up. Here in the northern states our winter blend fuel has additives in it to prevent against gelling in freezing temps. The cold temps were just as much of a surprise to the oil companies as it was to you. Under normal conditions your fuel would never need these agents as you'll rarely ever need them.
In the instance you went on a road trip up north in the winter, you would get fuel along the way that contained an additive to prevent this.
Get some Diesel 911, let it do it's thing and you'll be just fine. Your fuel filter may be gelled up as well since you've been cranking on it, but that should clear up once things warm up over the week.
https://www.hotshotsecret.com/why-your-diesel-fuel-is-gelling/
Capricorn
Las Vegas, NV
Jeep Wrangler JL Willys Unlimited 2021 3.0L EcoD, Dodge Durango R/T 2019
Network Architect & Engineer
I had the same issue! Mine did crank and started for a couple of seconds. I raised the hood let the sun warm it up. Got an indication I had water in my fuel filter. When it started I drove around a bit and moved one of my benz’s outside and the Jeep in. All is good now. I do NOT have the block heater cable for my Jeep.
Water in fuel - was it a false alarm?
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
I understand ALL our Eco Diesels came equipped with block heaters...but ONLY IF you ordered a block heater on your build sheet, it came with a cord. Supposedly you can go to the dealer and purchase the cord and connect it to the already installed heater...It's also suppose to be a MoFo to get to though.
Search around here, there was a thread about that a while back.
40”JLURD
Ross
Southern California
2021 JL Unlimited Rubicon Diesel
Bad Mother Fucker
It’s wanting to turn over but won’t fire up. No block heater. Battery has juice from What I can tell. It was in this colder weather all night.
I’d get a block heater ASAP if you live in those temps. Cold starting a diesel is the worst thing for the internals of the motor.
Good luck getting her to start by the way. Once you do; do yourself a favor and grab that Mopar block heater cord right away
Robbyreneeward
Robbyreneeward
Robby
2008 Dodge Ram 2500 Megacab
Thanks. Once in a lifetime storm here. I’m gonna leave it parked for now. Can’t do anything until temps rise, hopefully tomorrow or Saturday. Average low in north tx this time of year is 30-40 ish. Not -2
mtnmerlin
Ron
Tres Piedras, NM
2014 Jeep Grand Cherokee diesel, 2020 JLU Rubicon diesel
If you have electric power, I recommend attaching a battery charger/tender. I am not sure how it all works when cold, but the system may be using the battery to do things like keeping the DEF line from freezing. (DEF freezes below 12F.)
toolaide4fit
Tom
Waxahachie Texas
2020 Jeep Wrangler Rubicon Diesel, 2016 Mercedes C450 AMG, 2014 Mercedes ML-350 Blutec, 2005 Heritage Softail
IT Manager
Not sure, could have been some condensation. Once I got it running it was fine. I did run into a guy that had some diesel additive and put it in my fuel tank. He was driving a Chevy dually and after he asked if I was sure I had a diesel he offered it to me.
rickinAZ
Rick
Phoenix
2021 Rubicon Diesel
That made me smile. Does he think that you just have a confused look on your face when you are looking at the fuel pumps?
SolarWizard
SD, CA / Tampa, FL
Model Y Performance / Diesel Gladiator soon
energy management tech for homes and businesses
^ I agree with what you’re saying that’s why I own a ranch in CA but my legal residence is my house in Tampa. I also own a cabin on acreage in Wyoming though so I’m following this closely
Ruby Mike
Michael
Southern California
2020 jeep wrangler diesel
When I was living in the high country of Colorado people used a very cheap trick to keep the engine warm. They put an old fashioned incandescent light bulb into the engine compartment. It might be tough getting the old style of light bulbs, especially in California. But a single 100 watt bulb is enough to keep the battery and engine from freezing.
calemasters
Allen
Springfield, Mo.
2021 Rubicon Unlimited, & Escalade
Retired Mechanical Engineer
toolaide4fit
Tom
Waxahachie Texas
IT Manager
I get all kinds of looks at the diesel pump at the local truck stop, but when I pull up and put DPF in they get really confused.
I have had a few tell me “you know these are diesel pumps right?” And I say yep, it is cheaper than 91 octane!” Then drive away!
Superchips TrailDash 3
