3” lift and driveshafts
Nickb2787
Nick
Ohio
18 Wrangler Sport Unlimited
Do I need to worry about driveshaft issues with a 3” lift?
Moto_21
Erik
Corona
2018 JLU Sport
Maintenance
Depends on shock length. 30” shocks will rip the driveshaft slip joint boot. Mine been tore off for about 5,000 miles. No biggie
OffroadTreks
Boise, Idaho
2018 Jeep JLU 2.0TE
This. Just make regular inspections, as you should before and after any trail run anyhow.
People rushing to buy a $500 shaft just to to clear some rubbing seems a bit silly. But... whateverz. Run it till it breaks.
lightsout
PNW
When I installed my Rancho 3.5" I specifically called and talked to the Rancho engineers who said absolutely not needed, stock is just fine, However make sure you include either adjustable control arms or Geo Brackets to align the caster.
The only one I saw that suggested it was Rough Country who know that could be just to sell more stuff.
Here is a thread about Sport and Sahara Lifts (non Rubicon)
https://www.jlwranglerforums.com/fo...ahara-only-lift-kit-thread-non-rubicon.20211/
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
I encourage front ds on 3.5” lifts and above. They are relatively cheap insurance if you’re going to wheel. If it’s your daily driver and doesn’t get flexed out the stock one is fine. When we go on trips, we carry out stock for a backup. Takes about an hour to swap if things are hot.
Brett
Nickb2787
Nickb2787
Nick
Ohio
Thank you all for the quick input! I really appreciate it! The place I deal with is also calling the manufacturer to verify driveshaft angle and available caster plates. May just stick with 2.5”.
TTEChris
Houston, TX
www.tankcustoms.com
2021 JTD & 2021 4XE
It has little to do with lift height and more to do with shock down travel up front. The Mopar kit lifts closer to 3-3.5" but they use fairly short shocks up front. At a certain amount of down travel(Offroad, Flexing or on a lift) it will deform the alluminum joint housing on the driveshaft at the transfer case end eventually ripping the boot.
I've seen longer travel 2.5" kits cause the same damage to a driveshaft as 3.5" kits.
My JL driveshaft when I replaced it. Not torn, but you can see the damage to the housing.
This is a JK shaft I replaced last week, but same style as the JL
