295/70r18 on stock 80th anniversary wheels. Will I need spacers?
King Nothing
Jason
Illinois
2021 Gladiator
Getting ready to start gathering parts for my wife’s new 80th. Going with a 2.5 inch spacers loft and 295/70r18 Nitto Terra Grapplers. Will the 295s fit without rubbing on the street or will I need to spacer them out?
Stl_JLU
Nathan
St. Louis Missouri
2020 Wrangler High Altitude
If you run this setup please report back how it is working out. I’d like to see that!
Adam
Massachusetts
2021 Wrangler JLU
how did this work out did you have any rubbing? did you have to use spacers? getting ready to put 295/70r18 falken wildpeak at3 in my stock wheels sahara altitude with mopar lift.
King Nothing
Jason
Illinois
2021 Gladiator
its working well. Fit with no wheel spacers and no rubbing on the street. Haven’t, and probably won’t, had it Offroad. The wheels and tires are tucked way under the fenders so if you like the wide look this isn’t for you
no rubbing on the street, no spacers required. The wheels are tucked way under the fenders though so if you like the wide look you’ll need lower offset rims or spacers
DadJokes
Daniel
Kentucky
Sahara
My aggressive sidewall Baja Boss AT’s rubbed the lower control arms. Not enough to harm anything but has an easily audible noise and will rub paint off.
I ordered custom made Bora 1” black wheel spacers. Problem solved.
King Nothing
Jason
Illinois
2021 Gladiator
Our motto terra grapplers have smooth sidewalls so we don’t rub. I’m thinking about 1.25 inch spacers to move the tires out a little though for purely looks. Wife likes how my tires on my Gladiator poke out
DadJokes
Daniel
Kentucky
Sahara
Personally, I like a muscle car etc look. I’ll only go as far as the sidewalls themselves bulging past the fenders. There’s still decent tree protection for the fenders doing that with the level of obstacles and terrain we’ll traverse. 1” spacer on standard width axles but with Rubicon fenders does that perfectly with the 295’s. Basically, that is a stock Rubicon setup on 295’s with 1/4” extra poke on each side. Subtle.
Rock Krawler
