285/75/r17 on stock JL Sport
palmor
Mass
2019 Jeep Grand Cherokee High Altitude, 2018 JLU Moab
Anyone doing this tire size on a stock Moab? The KMs need replacing and I want to go a bit larger, since they fit sports I'm assuming they'll fit a Moab fine but wouldn't mind some feedback for people who may have done it
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Wandering Vaquero
You can look at Willys for comparison, since a Willys is essentially a less fancy Moab.
obriendr12
Daniel
Ohio
2020 JLU Willys
I’ve gotten a lot of inspiration on this thread. I love keeps and my first one was a 2002 TJ in which I pulled out the carpet and removed the backseat placing a bean bag chair for my 90 pound German Shepherd. My dream has been to build my own jeep so I thought I would share.
I have a 2020 JLU Willys. I added a 2.5 teraflex coil lift with shock extensions, 1 3/4 synergy wheel spacers and tinted the front windows. My muddy did all the word ( besides the tint).
Before:
Jeep Wrangler JL 285/75/r17 on stock JL Sport 26C89C7D-4FA7-46EB-A264-4FD8D0AE1BAA
Jeep Wrangler JL 285/75/r17 on stock JL Sport D1895344-4BC0-4904-8598-9090C117FB32
2.5 lift with stock tires
Jeep Wrangler JL 285/75/r17 on stock JL Sport 00390D77-9928-4373-A082-0E61CBAEAA2F
2.5 lift, spacers, 285/75/18
Jeep Wrangler JL 285/75/r17 on stock JL Sport 03B4FB2A-FFE1-452A-836B-7064001FE1E4
Jeep Wrangler JL 285/75/r17 on stock JL Sport EB7E0124-5D31-4064-AAD2-57050D44B4E5
Jeep Wrangler JL 285/75/r17 on stock JL Sport 6658B9A5-48C8-44E1-B857-DB7B1A7D885E
Jeep Wrangler JL 285/75/r17 on stock JL Sport C15C6620-B37F-4786-93F1-57CBF2DE7074
Jeep Wrangler JL 285/75/r17 on stock JL Sport EACA0399-F191-4AFF-8880-FF044255C878
CMTAZ
Phoenix
2024 JLURX Anvil
Yeah, I think the willys comes with Rubicon shocks/springs
The willy's comes with Rubi Shocks & Sport Springs (I've got a set of Rubi springs waiting to go on). It's a simple way to make your willy's as high as a rubicon. I'm running 285/75/R17 Toya AT's and the there is no rubbing at all, BUT I have not had it off road since the tire swap. I'll probably have the springs installed (measure it) and the either leave it or add a 1/2" spacer.
If you go this route you need to be aware that there are a boatload of spring part numbers for the rubi, and they all have an effect on how much lift you will get.
Shak14
St. Louis
2018 Wrangler JLU Sport S
Although I’m not on stock wheels, I did go to the Falken Wildpeak 285/75/r18. Previously had Falken Wildpeak 305/65r18.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
My coopers are E load but they feel like c load tires. They're super comfortable. They're very quiet as well. They're also the lightest tires in this size in an aggressive tread.
you still running these tires? what psi for street?
uralist
Eric
Cincinnati, OH
22 JLR - Sarge Green
I went with 285/75/r17 Ridge Grapplers on stock wheels. 4 door Rubi springs and shocks. It seemed a little sluggish at first with the 6 speed manual but now I’m used to it. This thread was a huge help in deciding between 33s and 34s.
Outrider1
Wisconsin
None yet
So I just did this tire size as well to my JL Willys and it seems I've got a little bit extra fender well room. According to my build sheet, I have 'standard' suspension (same as Sport/Sport S), but I do have red struts (assuming the same as the Rubi). When I go in for my first oil change, I'll ask them what the replacement part numbers would be to figure out some final truth.
All that being said, I love this tire size and don't really feel like I'll do much of a lift, if any.
Jeep Wrangler JL 285/75/r17 on stock JL Sport FBA25769-0425-4034-80D3-4EEDB64B3B1A
I have a 2021 Willys and your rig looks fantastic.
What exact tire and size is that? Did the spare fit on the stock bumber? Have you done any kind of offroading and did they rub?
After almost two years what pros or cons have you had?
Willys_Wonka
PA
JLUW
I’ve posted this in another post but here is my Willys with the 285/75/17 Toyo AT3’s, Rubicon springs and fenders.
I'm thinking about jumping from 285/70/17 to 285/75/17 on a JLUW. I have the rubicon springs and shocks installed, but can you confirm what Rubicon spring numbers you are running ( I have 60/61 and 91/92)? I'm debating if I'll also need coil spring spacers if i go to 34" rubber, possibly .75".
Punkn89
Alex
Maryland
2019 Wrangler JLU Sahara
This thread inspired me to get the 285/75r17 toyos. I honestly wouldn’t recommend putting them on a stock Jeep, you’ll have barely any clearance (aside from rubicons). This is on a Teraflex st1 kit.
Knel6
Kody
WA
2020 Jeep Willys
FYI
any photos from the front/back to show wheel spacing! I’ve been curious about this size and how wide they end up being - granted a lot of that depends on wheel type. How noticeable was the swap driving wise, did you move up from stock tires? How did the spare fit, any modifications needed there?
Punkn89
Alex
Maryland
FYI
pics on the link in my signature :)
driving wise, you feel more planted to the road with no power loss. I did get the rough country spare tire bracket which I might not have even needed so there is plenty of space between the bumper and spare. It also is not as heavy being a C load which puts less strain on the tailgate.
