285/75/18 on stock spare carrier?
Fdcjames
Jeremy
Ohio
2018 wrangler
Anyone know if this will fit?
I’ve got a 285/70/r17 on my base sport. Only thing I had to do was trim down the rubber stops/isolators on the tailgate to fit the wider tire. They pop right out and back in no problem.
Vedder
Shannon
Sudbury, Ontario, Canada
2018 Sahara Unlimited
Sorry.. this size was to say 285/75/18.. not 70. These are quite a bit taller than 285/70/17. But thanks for the info.
Jeepit
DB
Il
2018 JL Unlimited Sahara
I think it will depend on the tire you buy
I just put Cooper 285/75R18 on my JLU Sahara
stock wheels, no lift, no spacers
they fit fine no clearance issues on the axles
but they measure a true 35.1 diameter
and I had to add a Rough Country spare tire bracket
also re-used stock bump stops from an 13 Rubicon and cut 3/8 off length
it also just about completely blocks the back window
JLJoy
Wichita
2021 Rubicon JLU 3.0 Diesel
I just mounted my 285x75 18 on the spare tire carrier and it fits fine. I do have the Fuel Trophy wheels so it pushes the tire and wheel away from the vehicle.
jawsATL
Alan
Georgia
2019 JLU Granite Metallic Sahara
JeepIt -- Anyway you could snap some pics from the side and front of your setup? i am looking at trying to add a 34.5 - 35 inch tire to my Sahara on stock wheels and was thinking the 285 75 18 would be perfect, and of course seeing it would help. Not sure if I should lift a couple of inches though...
PSC Motorsports
