285/75/17 on my 2020 JLU Sport S?
rsmit42
Robert
Valley Grande Alabama
2020 Jeep Wrangler Unlimited Sport S
I want to run 285/75/17 on my 2020 JLU Sport S. What all is involved to be able to do this? It came with 245/75/17 tires on it.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I'm a fan of suspension over spacers, so I would personally get a set of Rubi takeoffs. Preferably, a set taken off of one that came from the factory with the hardtop/steel bumper/tow package combo. Supplementing that with a quality set of adjustable front lower control arms would allow the fine tuning of caster. You could stop there and slap on the larger tires, and keep costs at a minimum.
If you wanted to take it a step further, adjustable front and rear track bars to perfectly center the axles side to side.
Higher quality arms and linkages from quality aftermarket companies are stronger than factory and resist flexing. They also have much better performing bushings. This results in a more solid and planted feel to the ride and handling. The more that gets upgraded, the more that feeling will grow.
Welcome to the community!
Abend
Jeremy
Erlanger, KY
2019 Hellayella JLUR, 1948 CJ-2A, 2018 Sting Gray JLU Sport (the wife's)
You can run 285/70/R17 (same size that comes stock on the Rubicon) with no lift - my wife's Sport has been running that size since I upgraded my jeep to 35x12.50 tires a year ago. Your speedometer will register 2-3mph slower than actual speed at highway speeds without an adjustment, but clearance is no problem at all. You'd need a small lift for the 285/75/R17.
rsmit42
Robert
USMC0311
Oslo
Ogden, UT
2020 JLU diesel Rubicon
Mine came with 285/70/17, I switched to 35x12.5x20
MadDog27
Jon
Aurora, Colorado
2022 Tacoma
I had the dealer put my 285/75/ 17s from my JK on my JL when I purchased it. They fit but it will rub when at full lock. I got home after hearing the rubbing and removed the fender to bumper things by unbolting it for the bumper. Problem solved!
I eventually installed a 2.5 spacer lift but I ran it with no lift for a bit. If you remove those connector fender things, you’ll be fine!
rsmit42
Robert
Thanks!
Before and after lift. First 2 pics are no lift with 285/75/17s.
2nd pics is with a 2.5 spacer lift.
Last pic is current.:like:
Jeep Wrangler JL 285/75/17 on my 2020 JLU Sport S? A1385A14-354E-42C6-A944-AC146DF44906
Thanks! I like the lift! What type of rims are you using? BTW,your Jeep is the same color as mine.
Roger C
Arizona
2020 JLUS
Jeremy, which wheels are you using on the Sport and if they are aftermarket, what is the backspacing?
MadDog27
Jon
Aurora, Colorado
2022 Tacoma
Thanks!
Lol, well....may have to get back to you on that. I’m not sure.
Haha, picked them up on offer up or Craigslist a while back for $400 5 rims and tires. 4 of the tires were worn and I eventually replaced them.
They say American Racing ATX series with Teflon coating. If I find the actual type, I’ll drop it here.
Abend
Jeremy
Erlanger, KY
They're on stock alloy wheels - we just moved them straight over to the Sport from my Rubicon and then sold her original wheels/tires.
OregonJeepGuy
Oregon, duh!
2018 JLUS Sting Gray
Old retired guy
Cooper AT3 XLT, in 285/75/17, on stock granite crystal wheels. Rubicon suspension. Close fit with the spare on the stock rear bumper, but no issues.
Jeep Wrangler JL 285/75/17 on my 2020 JLU Sport S? D9F0D346-D5D5-447F-AB16-ED9D0AD5B27F
Jeep Wrangler JL 285/75/17 on my 2020 JLU Sport S? F80C514F-619E-4658-AA65-77E81417F150
Jeep Wrangler JL 285/75/17 on my 2020 JLU Sport S? 262BA362-4B7F-45D8-84F0-235EB945EF88
Knel6
Kody
WA
2020 Jeep Willys
Nice looking Jeep, how do you like the coopers? Any rubbing with the Rubi takeoff suspension? Was there a noticeable difference in handling and overall performance with the tire and/or the suspension upgrade? I’ve been considering this tire size, my Jeep is a daily driver and I don’t want to go too big and lose the stock handling/performance.
