285/70/17 on 2 Door Sport
DaKushyMonster
Alec
Pittsburgh
2019 Wrangler Sport 2 door soft top
I appreciate you trying to help! But this video is not the 2019 JL :(.....The t25 torx driver is not what is used for the 2019, It wound up being just the 7mm socket for all the screws!
DaKushyMonster
Alec
Pittsburgh
Got em out. Wound up being just a 7mm socket, but needed to remove the air dam w a 8 or 10mm socket (cant remember now). One before and some afters! Made a bad video of doing it!
Bee-Rad
Austin, TX
2019 JL Sport
Post pics if you have 285/70/17s on your 2 door JL! I have 33” Wrangler Duratrac with a 1.5” teraflex performance kit and 1.5” wheel spacers. No rubbing so far, haven’t taken offroad yet.
This is EXACTLY what I had in mind for mine!
DaKushyMonster
Alec
Pittsburgh
Haha, I couldn’t find any references with the 2 door to see if it worked before I did it, so glad I could show you what it will look like!
Uhdinator
Maine
2018 JL Sport HT 2.0T Auto, 2003 TJ Rubicon HT
Well if you're going to add a slight spacer lift (2")..........
305/65 will also fit but my wheels are 8.5" width 5.2 back spacing vs stock 6.2?
VooDoo1
Don
Sacramento, CA
2018 JL Sport S, 2007 FJ Cruiser
That is the same setup I have been looking at, but hesitant to pull the trigger until I knew exactly what it looked like. It is exactly what I want to do. Thanks for posting. I'm currently running stock Sport S suspension with 17 X 9 (+1 offset) wheels and 285/70R17 KO2's. Placing my order for the Teraflex 1.5" Performance kit. Thanks,
grnfrog75
Heather
Virginia
2021 Wrangler JLU Rubicon
285/70R17 KO2 on sport with Rubi take off suspension
I'm extremely new to the Jeep scene, purchased my 2018 JL Sport used back in August. Went wheelin' this past weekend and realized I need a bit of an upgrade, lol. Someone in my Jeep club is offering me their stock Rubicon suspension and wheels/tires. I'm not sure of the lingo yet, but is this what you did? Will that work without any issues?
1quick1
Moderator
Moderator
2018 JLUS
Yes, you can swap in the Rubicon suspension and you'll like get 1.5" of lift or so and will be able to fit some 33" tires no problem.
grnfrog75
Heather
Virginia
Ok, great! And the Rubi stock tires are 33" I'm assuming? When looking at lifts I only wanted to do a max of 2" anyways, because I'm short. Didn't want to use a ladder to get it the thing! Besides this is my my only vehicle and need it decent for the street as well.
Thanks!
Combat Chuck
Chuck
Motor City Detroit
Sarge Green JL Willys
Kushy, what wheel spacers do you have? Did you have to grind down your wheel studs with the 1.5" wheel spacers to clear your steel wheels, or do the steelie wheels have pockets that clear the studs like the factory aluminum wheels do?
Ogre_FL
Cooks Bayou, FL
2018 JL 2 Door Sport S, 2021 Gladiator 80th
Thanks!
We dont like running boards and did not want the Jeep too tall to easily get in/out of.
We simply put the Rubicon take off wheels & tires (33's 285-70/17) on without any lift.
No rubbing issues.
Arrowhead
George
Stillwater, NY
2018 Wrangler JL Sport
Thanks!
I did the Rubi 4dr suspension/tires/wheels takeoffs and am very pleased. It looks good and rides nice and not too tall (for now). Got about 1.5" of lift from the springs and about another 1" from the tires.
