26k brake fluid flush
Brooklynjlu2018
Junior
Massachusetts
2018 wrangler sahara
I changed my brakes to something with a lil nore stopping power so I figured i would flush the fluid and it was brown. Like new motor oil brown any one else run into this :whatsgoingon::whatsgoingon:
Brooklynjlu2018
Brooklynjlu2018
Junior
Massachusetts
I dont think so. I drive alot of aggressive highway driving so i chalked it up to that. I replaced with lucas synthetic dot3 supposed to have a higher temp Rating we will see
blnewt
New Mexico
Just ask @cosine he knows!
What brake upgrades did you do? If it was just pads, do tell :)
#4Jeep 1st Wrangler
mark
north olmsted ohio
Looks pretty nasty.... I know that most " import" vehicles owners manuals call for brake fluid exchange at 3yr/36k intervals. Most owners are not aware it should be changed... Any time you have different metals in a brake system, and you add a fluid, you can get corrosion internally.
I've changed many that the fluid has greenish tint due to copper in the valves etc..
Brake fluid is "hydroscopic" ( absorbs moisture)..
Looks like I will probably flush mine earlier than planned...
Brooklynjlu2018
Brooklynjlu2018
Junior
Massachusetts
Just pads at the moment the z36 extreme duty. Ebc is set to release their rotors and orange stuff pads very soon but weren’t available right now
Brooklynjlu2018
Brooklynjlu2018
Junior
Massachusetts
Yeah ive never seen it that brown before its only 2 years old i switched to lucas racing synthetic dot 3 and will see if it holds up any better
VNT
Maine
SRT Challenger, 2015 Hemi Overland, 02 WJ 4.7, 2000 Durango, PT Cruisers, 2018 Punkn Sahara 2020 OB Rubicon
Pretty much normal, I bleed a lot of brakes every year ( have10 cars so every 3 or so years, freshen up the fluid) and the fluids slowly become darker tan. Only strange one is my 15 Hemi WK2, the fluid turns a tinge green. I usually flush the whole system with a qt of Prestone Dot 3. Yearly I will suction and refresh the reservoir.
If your bleeding and flushing brakes, that is good maintenance practice. Also go take a look at some of your friends reservoirs that never do it and look at the color of the fluid. Freinds with local dealer techs and visit the bays often, the fluid in some of them are almost black. Total lack of PM.
