2026 model year frame bracket change
Upnover
Michigan
None
I got a 26 Moab and it has the older single bracket on the passenger side. Weird they are all different.
gato
New England
2021 JLUR
It just depends on when yours was built. It was a running change at the very begining of the 2026 MY. I think anything built from December on has the new style brackets and, some November builds are mixed.
gato
New England
2021 JLUR
No, but each bolt weighs about 6 oz. according to my wife's cooking scale. So about 5.25 lbs for 14 bolts.
Thanks for weighing it.
You should keep the bolts in the Jeep. If you ever driving over a bridge or other large steel structure that is about to fail, you can just use those bolts to keep it together - the 4 black bolts alone could probably anchor any bridge in America.
Atomic5
FL 🐴
26-JTR 23-JLR 🛸
The welded frame nuts for the brackets are 24 mm. One of mine broke loose and luckily I was able to get a wrench on it.
Richard_JL
Larry
Boca Raton, FL
2026 JLU Rubicon 3.6L
IT Director
My 2026 luckily doens't have that ugly thing. Build date was October 2025.
BCTrails4x4
Eric
Delta, BC
2024 Jeep Willys
Mm. We'd first want to confirm their purpose. Perhaps rollover mitigation?
That knowledge would allow owners to make an informed choice about the brackets' removal, if they interfere with accessory installation.
i think if it’s a safety issue like all other recalls, then Stillantis should be doing a massive recall to install this bracket. One shouldn’t have to think to buy a ’26 just for this upgrade.
daytoncarter
Dayton
Washington
2025 Ford Ranger
Despite flipping the driver injuries were low! Many cars perform worse with broken legs, heads, etc.
ag4ever
‘82 CJ-8, ‘82 CJ-8, ‘83 CJ-8, ‘26 Moab 392
My 2/14/26 built Moab has the old style bracket.
BCTrails4x4
Eric
Delta, BC
2024 Jeep Willys
If it's a safety modification (which seems likely), I'd like to add it if possible. I'm all for a safer Jeep. I was a little bummed when I saw that side curtain airbags were added the year after I bought mine.
i would agree, safety upgrades should never be an upgrade for you to buy, it’s should always be a recall. I think the way they look at wranglers is that it’s customizable and this is just like an add on feature(at least that’s how they’re categorizing it).
link3721
Tom
North Carolina
2023 JLU Rubicon 4xe High Velocity
Since this is an IIHS (insurance company group) test it's not something they'd do a recall of. If it was an NHTSA (federal govt) test then yes a recall is a potential remedy. So really the additional bracket will help insurance rates be lower on newer Wranglers.
gato
New England
2021 JLUR
The brackets are *NOT* retrofittable to earlier frames. There are a lot of changes to the frame with extra holes with captured nuts inside, hanger pins, etc. It is really a frame redesign.
jldby
scottsdale arizona
26 Rubicon X
I have been looking for side steps or rock rails and several manufacturers have said theirs don’t fit including rock hard LOD and Rough Country.
