Chocolate Thunder
Probably not what you want to hear, but the AAL were fairly straightforward. The only issues I had were Chocolate Thunder related and not AAL related. I had a little trouble with the front driver side one because of the SteerSmarts track bar reinforcement bracket being slightly in the way. @Headbarcode helped me through that because he has it too. There is a bit of contortion required to get the holes to line up the first time. Not bad for me because I have the strength of 10 men. 3-4 out of 10 different for a mortal. The Dzus quick release fasteners they use are great. The connect with a definite audible and tactile click when it clips into place, there’s no issue with cross threading a regular threaded bolt. The only other issue was a little difficulty installing a few of the rivnuts. That’s 100% on me, I hadn’t used those in forever. I was too cheap to just buy the tool so I used the DIY install method of an impact gun and socket, bolt, washers, and nuts. Don’t do that. I buggered a couple of the rivnut holes over torquing it. But I was able to make them all work in the end, just spent an extra hour or two and a couple trips to the hardware store and some swearing.Soooooo, the Artec front fender liners arrived. I go to install as per their install video….nope. These things are a PITA. The rears were a pain, but I powered through because they aren’t covering anything I need to get to for maintenance. But the fronts….no thank you. I am okay with she hulking things when needed, but not the liners. I need them to be easy-ish to install and more so to remove. Also….I have a set of front Artec liners for sale
On that note, @Chocolate Thunder , how is the install on the front AAL liners?
