2021 Rubicon wandering
chadk77
Chad
Austinville, VA
2004 TJ, 2021 JLURubicon
Picked up my 2021 Rubicon on Oct. 3rd. It has the new steering gear box and it doesn't have any dead spot in the steering but it's very unpredictable at speeds over 45 MPH, it's hard to keep in the lane at 70+ and the steering feels loose. It wanders quite a bit. Super sensitive to grooves in the road or uneven roads. It responds when I turn the wheel it's just as if it needs a stiffer steering stabilizer or the toe is out. Anyone else have this issue on a 2021? Think I'm going to take it and have it looked at and maybe order a Falcon stabilizer or the Fox 2.0 adjustable ATS. Anyone have any reviews of either of those on here?
Rubicon_10
Richard
South Florida
2-door 6 speed Rubicon JL
Picked up my 2021 Rubicon on Oct. 3rd. It has the new steering gear box and it doesn't have any dead spot in the steering but it's very unpredictable at speeds over 45 MPH. It seems and hard to keep in the lane at 70+ and the steering feels loose. It wanders quite a bit. Super sensitive to grooves in the road or uneven roads. It responds when I turn the wheel it's just as if it needs a stiffer steering stabilizer or the toe is out. Anyone else have this issue on a 2021? Think I'm going to take it and have it looked at and maybe order a Falcon stabilizer or the Fox 2.0 adjustable ATS. Anyone have any reviews of either of those on here?
I feel the same about mine.
Roky
Roky
Steering stabilizer not the problem, likely you just need more caster. Rubis are low from factory due to their increase in ride height.
JayJay
Johnny
North Georgia
'20 JLR
I installed the longer Mopar lower control arms which increased the caster from 4+ to 6+. That really improved the straight line tracking.
Later,
Johnny
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Later,
Johnny
Also check tire pressure.
rickinAZ
Rick
Phoenix
2021 Rubicon EcoDiesel (11th Jeep)
Everything that I've read says you have a caster problem due to too short LCAs. I have the same issue and, after a lot of research (on here), I'm installing adjustable lower control arms.
LooselyHeldPlans
Brandon
Denver
2020 3.6 JLUR
Several
Welcome to the freaking club.
chadk77
chadk77
Chad
Austinville, VA
My 04' TJ drives better on the highway than this thing does. Pretty frustrating having a $60K Wrangler and the wife not wanting to drive it on the highway because of this. Guess I'll look into some front control arms.
rickinAZ
Rick
Phoenix
First step is the measure your caster (3rd link). If it's less than 6 degrees, you may have the solution to your wandering:
https://www.jlwranglerforums.com/forum/threads/big-driving-improvement-after-lca-swap.54439/
https://www.jlwranglerforums.com/forum/threads/mopar-lca-swap.22474/
https://www.jlwranglerforums.com/forum/threads/jl-rubicon-caster-measure.25691/
blnewt
New Mexico
Just ask @cosine he knows!
rickinAZ
Rick
Phoenix
Hawkian
Ian
Iowa
2021 Wrangler Rubicon
I have 2021 JLUR with 500 miles and have not experienced this problem.
SlowPoke21
Brent
Ohio
2021 JLUR
I have a 2021 JLUR as well. I also feel that it does not track well at high speeds. Wife noticed it too.
rickinAZ
Rick
Phoenix
Mine is lifted by 2" in the front. The Rubicon is already caster-challenged compared to the Sport/Sahara, and the lift just amplifies that.
