2021 rubicon steering “off center”
Fuser
Narci
Houston
2013 wrangler jk
Got a 2021 rubi back in December, it now has 4500 miles and on Friday my wife texted me this picture, took it to the dealer the same day, called them today and they haven’t diagnosed it yet. Anyone else had this issue?
Jeep Wrangler JL 2021 rubicon steering “off center” CBBF78C2-C69A-4F0C-9989-2F224173B94B
RFR JLR 2.0
Rudy
Simi Valley, CA
2019 Jeep JLU Rubicon 3.6L
Geologist
What did your wife hit? I hit a large rock on a trail and that happened. Was a simple adjustment to get it straight again.
JPAloha
Calgary
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE
Accredited Financial Planner
Adjust the drag link and get it straight again.
zeebo56
Zee
los angeles
2020 jeep wrangler unlimited sport
Simple fix. 15mm socket and a large vice grips or similar to adjust the drag link. I'm sure there are videos around. Will take you maybe 5-10 min to center it. Usually you center it and drives around but it may still be off so you stop and adjust a little more till you get it where you want and then tighten the 15mm down all the way.
brewdad
Alabama
2019 Ram; 2014 T&C
This is a covered warranty fix at your Jeep dealership.
Maverick909
Inland Empire
www.instagram.com
simple 5 min fix. with a 15mm. just have to adjust the drag link. not a big deal. but id be currious what knocked it out
Fuser
Narci
Houston
2013 wrangler jk
Got the Jeep back today. They adjusted the “toe” wife said she didn’t hit anything
aldo98229
Aldo
Bellingham, WA
Market Research
Riiiiight... ;)
I had this happen on the trail a few times to my JKs.
It takes a pretty big blow to one of the front tires. Hitting a tall parking stop or a curb pretty hard would do it.
It truly is a 10 minute fix.
The dealer will straighten it once or twice free of charge as a courtesy. But if you keep bringing it in for this they will charge you.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Can happen if you are parked very close to a high curb, or a wall, and you keep forcing the steering wheel till your front tires are jammed against the wall/curb.
