demisx
- Dee
- Jul 9, 2020
- Desert Hot Springs, CA
- Wrangler JLU Rubicon
Hello fellas. A couple of days ago I got into my 2021 4-dr. JLUR (manual, dual 12V batteries with ESS), pressed the clutch, pushed the start button, and … my almost brand new “since 1941”’ icon will not start. And, of course, this had to happen right before our planned weekend trip.
Here is what happens when I try to start:
I’ve spent two days going through our forum and trying different things, but no luck. The first thing was to check both batteries. I’ve tested them in isolation and both shown 12.xV voltage. I left the battery tender overnight and brought the charge in both to green. I’ve tried to jump start with a battery pack - still no luck.
Any idea what maybe wrong? Thank you all.
- I push the start button to switch to the ACC mode. Everything powers up and loads as normal.
- I then press the clutch and push start button to start the engine. I hear a click and then Uconnect 8.4” screen goes black. There is no attempt from the starter to turn over.
- I let the start button go and the Uconnect screen come back on again.
- I try this two more times and the same thing happens each time.
- Here is the video that shows this process (3 start attempts total)
