2021 JLU Oil Pan / Transmission Skid Plate Availability
mnjeeper
MN
98 TJ, 2021 JLUR
Hi from Israel!
As we haven't tested these on a vehicle with these specs we can't confirm it will. The way ASFIR works is by test-fitting all of our products "hands-on" to make sure it's a perfect fit.
We'll look for one like this to fetch and test here. stay tuned :)
Cheers,
Reut @ ASFIR
You just hit my radar. Great price for the offering! Do you know if clearance is lost, gained, or the same with your skids?
ASFIR4X4
AZ, USA
TJ, JK, JL, Gladiator
We haven't measured it to exact numbers, but there is some clearance loss. I can't say exactly what will be the clearance loss, but a wild guess is 1-2 inch.
We'll do some homework and get back to you with some more accurate numbers.
mnjeeper
MN
98 TJ, 2021 JLUR
Appreciate that! Clearance loss sucks, but if it comes with a smooth slide...might be a wash.
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
The only clearance I lost was the thickness of the aluminum. 1/4”?
ASFIR4X4
AZ, USA
Jeep Wrangler JL 2021 JLU Oil Pan / Transmission Skid Plate Availability B16CF156-76D6-4E40-BAC7-48A4D5BBD886
It usually is! sometimes tho, the brackets (connectors) can get some extra clearence loss but it just really depends on the plate and vehicle.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
the hole/opening for the oil drain plug. is it big enough to reach in to remove the plug? so you can do an oil change with the skid plate in place. hard to tell from the pics.
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
Yes. I am considering lengthening the hole towards the rear a half of an inch or so with my carbide burr as the stream of oil can catch there causing it to run down the length of the skid plate coming out the two rear holes pictured. That was a mess to clean up. My garage floor has a very slight grade to it although at least one other person here mentioned the same problem.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
i would recommend getting a Fumoto valve. you can get one that is angled down or to a direction. with a nipple that can add a rubber hose to it so you can direct the oil right into a container. i wouldnt run one without a skid plate but with the armor you'd be G2G.
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
Eh…it’s not that big of a deal to carbide it once. IF I smash the skid (a consumable item for sure) having anything with more length than needed just adds leverage to crack and break the threaded area of the oil pan. I prefer nothing but a bolt head there.
mnjeeper
MN
98 TJ, 2021 JLUR
Well, ASFIR got my order and I added the etorque skid (seemed a no brainer). I want to give props to the customer service that I didn't even reach out to. I got an estimated ship date (automatic, not sure) and it really wasn't bad, especially coming across the pond. Then, I got a message from them that they were beating the estimate. By quite a bit. They must know we NEED toys immediately :)
Works perfect for me because I will have it before my next trip offroad and I wouldn't have with original estimate.
AZ Hella
Sonoran Desert
JLUR
They have excellent customer service. When I ordered for my 2020 last year, I received it in less than 1 week.
mnjeeper
MN
98 TJ, 2021 JLUR
My Asfir skids arrived today. Early.
Cannot install today as I need to make an out of state run for the 4th of July ;) Has to be today, because tomorrow I have a new pup coming to stay (foster) so I can see how a dog fits in life these days. Hopefully he loves the Jeep.
mnjeeper
MN
98 TJ, 2021 JLUR
Does anyone know of these are still the only options for 2021+ Pentastars? Love the low weight of the ASFIR plate but it’s pricey.
I actually found it to be cheap compared to Artec and NV...the others I was waiting on. They also have a skid for the etorque for like $120.
