2021 JLU Oil Pan / Transmission Skid Plate Availability
Buddy Lee
Victor
San Martin, California
2021 JL Rubicon Unlimited
What models have the new mounts. I have a 2021 Rubicon unlimited with the 2.0 and so does my friend. they were ordered in late November and I picked it up December 30th. I ordered the Artec Aluminum Fully belly skid plate and it fit perfectly. The engine brackets bolted right up.
Jeepmanic
2021 Jeep Wrangler unlimited rubicon
Semi retired
My 2021 jlur with 3.6L has the new mounts.
mnjeeper
MN
98 TJ, 2021 JLUR
I think it's just the 3.6 from the people I see talking about it.
Billy goat
Phoenix
Jl sport. Ford Focus st
I’m bummed man. I need the engine/transmission skid. I wheel hard no lift. That piece of armor has saved my ass on many occasions.
I hope we see solutions sooner than later.
staindvans
Travis
WI
2021 Jeep Wrangler Unlimited Rubicon
Has anyone confirmed it is just the 2021 3.6 that has the changes? Is the 2021 2.0 the same as previous year? Looking to buy some skids soon and wanted to make sure I get ones that will fit. If it helps at all I can take pictures and measurements under my 2021 2.0 to verify.
DarkAardvark
2000 TJ
Yeah I'm also curious about this. Or if things did change, when? Is it all 2021s or only 2021s after a certain build date? Are there any pictures of the differences so we can check?
mnjeeper
MN
98 TJ, 2021 JLUR
Also an interesting question. Mine is an early 2021...so I would check if I knew what to check. I have a feeling it's not easy to spot visually.
DarkAardvark
2000 TJ
Yeah, like I have an early 2021 as well and pre2021 diff skids fit, while others had issues with their later 2021s
Jeepmanic
Semi retired
The motor mounts on new 2021 jlu look like this.
DarkAardvark
2000 TJ
Here's mine:
Built oct 2020
2door, V6, manual, no etorque or whatever
They look identical other than it looks like I have an extra bracket on the top right of the picture (but it's probably because I'm zoomed out more)
Kreepin1
Kirk
Central Illinois
1982 CJ7, 2006 TJ, 2012 JKR, 2021 JLR
Talking with Artec 4 weeks ago, they said the 2021 change only affects 3.6 engines. FCA changed the motor mounts to be the same as on a 2.0, so it was a move to reduce the size of the parts bin.
And before you ask, no, you can't just use the brackets from a 2.0 skid plate because everything else is different so they don't match up.
staindvans
Travis
WI
You sir are a gentleman and a scholar?
Chrysler Factory Warranty
