I don’t need the door open. But I am capable of holding door without a seat belt to pull through gate.And why would you need to have the door open to do that? Auto Park will not engage if the door is closed.
Just close the door, or buckle the seat belt. You can just buckle the belt behind you.I don’t need the door open. But I am capable of holding door without a seat belt to pull through gate.
My first experience with a Nanny State door was the first hunt with my 89 bronco. Spot buck , open door, DING DING DING DING!!!!What if I'm road hunting. Hard to shoot with my seat belt on and that window is awful small to swing a barrel out
Obviously,since it’s now required to move vehicle a few feet through gate, out of garage, hook or unhook from RV etc.Just close the door, or buckle the seat belt. You can just buckle the belt behind you.
Also, read the owners manual.
Lawn mower wouldn’t listen so I used a jumper wire.These same guys out there yelling at their lawn mower for shutting off when they get off the seat. WHAT IF I WANT TO STAND
No!I’m the past and in other vehicles, I have had to have my door open while backing in a trailer when I couldn’t trust my mirrors, seat belt off because I was jumping in and out. Can I not do this with my wrangler?
Use the backup camera. It’s dead ass accurate.I’m the past and in other vehicles, I have had to have my door open while backing in a trailer when I couldn’t trust my mirrors, seat belt off because I was jumping in and out. Can I not do this with my wrangler?
Ok, I knew it was a joke. I did not miss the point. The reason we have all kinds of crap in our life is because someone somewhere did something stupid, or just plain messed up. Accidents happen, if it were planned it would not be an accident. There are times you might want to have your seatbelt off and open the door. Is it 100% safe, probably not. But one instance is when I had my TJ, I had marks on the garage floor where I would back up to place my tires exactly where I wanted them to take the top off with the winch on the ceiling. So I would lean out a little while I was idling to where I wanted to stop. I understood the risk I was taking, but did it anyway.Firstly, the organ donor comment was an (I thought obvious) attempt at humor (obviously not successful).
Secondly, you must be missing the point. The reason why we have autopark is *precisely* because someone was run over and killed (presumably becoming an organ donor ***** in their driveway *****. Not to mention the multiple instances of pedal missaplication with people bolting out of their driveways and hiting houses, trees, cars, etc.
There are multiple documented instances (many on youtube) of someone opening their doors without a seatbelt in low speed scenarios (e.g. to pay for parking, to look at something outside, falling off and being injured or killed.
To repeat....if your door is closed, no autopark. If your seatbelt in buckled (or faked), no autopark. Open the door without seatbelt = autopark.
Hell no, and you are damn lucky to be with us today with that kind of reckless behavior.I’m the past and in other vehicles, I have had to have my door open while backing in a trailer when I couldn’t trust my mirrors, seat belt off because I was jumping in and out. Can I not do this with my wrangler?
This will only work if you don’t squirm in the seat too much…with the doors off, the system uses the weight sensor in the seat along with the seatbelt sensor. There are other conditions that come into play as well…it’s all in the owners manual…Lets see here, slammed itself in park when I was pulling it on my trailer the other day, you think a person needs a seatbelt in that instance? Also did it pulling into my lift bay, not exactly a high speed scenario.
Since I have no power options at the door, think I'm going to try to just disconnect it permanently and see what happens.
Because that worked well for this guyI’m the past and in other vehicles, I have had to have my door open while backing in a trailer when I couldn’t trust my mirrors, seat belt off because I was jumping in and out. Can I not do this with my wrangler?
