2021 JL Over pressurized gas tank.
Gman2717
Gary
North Myrtle Beach
2021 2 door JL
I recently purchased a 2021 JL 2 door and when I went to get gas in it for the first time I had to trickle it in due to the pump constantly clicking off. I contacted my local jeep dealer that told me the gas tank was faulty and that it was over pressurized from the factory and would need to be replaced. Just wondering if anyone else has had or heard of this problem. They have to take my brand new jeep apart to install a new tank.
Maverick909
Inland Empire
www.instagram.com
i've had this happen on many of my vehicles. nowadays the pumps are fueling up to fast for the factory vapor vent which causes back pressure and clicks the pump handle into a safe off position so you do not spill fuel every where. I cannot say ive heard of a dealer replacing a tank from " over pressuring a fuel tank " seems weird to me.. take it to another fuel station and see fi you have the same problem.
neil
neil
Dallas, TX
20 JLUR, 21 JLUR and others
pull the pump a mil or two out once you seat it.
Gman2717
Gary
North Myrtle Beach
2021 2 door JL
Tried all of that even put the nozzle upside down. The dealership said no matter what you do the pressure will not allow the gas to enter the tank as it should.
Chupacabra
Greenville, SC
2021 JLU
Maybe the filler neck is crimped or something causing your issue? Gas tanks are not pressurized with the filler cap off.
Ja87sm
Ct
21 wrangler islander
Our 21 did that the first time we filled it. I was able to move it a little bit and get it to fill. The second time I had no issues what so ever.
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
There is a check valve at the tank end of the filler neck, it likely got stuck. It’s not unheard of.
Bocephus
Virginia
Sam’s Decorative Automotive Button Emporium
I kind of had this issue. Became less of an issue over time. Jiggle the handle and back it up, back it in. I’d give it some time and before I took it in for a tank replacement.
