BigRedVegas
What’s the top end?
Personally I'm dying to see it in 4H smoking those 33's
Updated with Wrangler 392 commercial:
Cliff Notes:
- 6.4-liter V8 w/ 470-horsepower and 470 lb.-ft. of torque w/ cylinder deactivation
- Greater off-road capability - Better approach and departure angles, suspension articulation, and water traversing up to 32.5-inches
- 10.3-inch ground clearance
- Approach, breakover and departure angles of 44.5, 22.6, and 37.5 degrees, respectively
- 0-60 in 4.5 seconds and 1/4 mile in 13.0 seconds
- TorqueFlite Eight-Speed Automatic Transmission w/ paddle shift
- Selec-Trac two-speed transfer case with full-time 4WD, wide track Dana 44 axles with Tru-Lok electronic locking diffs, and electronic front sway-bar disconnect. 3.73 final drive ratio
- Upgraded frame rails, factory Mopar 2-inch lift, unique suspension geometry, heavy-duty
- brakes. FOX high-performance shocks
- 33-inch tires on 17" beadlock capable wheels standard
- 48:1 Crawl Ratio
- Dual-Mode Exhaust w/ quad tailpipes
- Functional Hood Scoop with Tri-Level Hydro-Guide
- Air intake can channel up to 15 gallons of water a minute away from the engine
- A secondary air path built into the hood allows the engine to get up to top speed even if the hood scoop is obscured
- Off-road Plus mode locks rear axle at high speeds in 4H
- Model-specific bronze accents
- Leather-wrapped performance steering wheel w/ model specific leather seats with additional bolstering
- New half-doors available
- Standard packages on the Wrangler Rubicon 392
- Leather interior
- Infotainment Group
- HD electrical switch bank
- Body-color hardtop
- Body-color flares
- Steel Bumper Group
- LED Lighting Group
- Cold Weather Group
- Remote proximity entry
- Safety Group Advanced Safety Group
- Pricing TBD
Official Jeep Press Release:
November 17, 2020 , Auburn Hills, Mich. - For enthusiasts who crave soul-stirring, legendary off-road performance and a new level of on-road performance, Jeep® introduces the V-8-powered 2021 Jeep Wrangler Rubicon 392.
The most capable, quickest, most powerful Wrangler carries the 6.4-liter V-8, rated at 470 horsepower and 470 lb-ft of torque. Mated to the crisp-shifting TorqueFlite eight-speed automatic transmission and Selec-Trac full-time active transfer case, the powertrain rockets the Jeep Wrangler Rubicon 392 from 0-60 mph in 4.5 seconds and the quartermile in 13.0 seconds. Plus, this potent combination comes with a factory-backed warranty.
Away from the pavement, the Trail Rated Wrangler Rubicon 392’s potent powertrain meshes with heavy-duty wide track Dana 44 axles, a 3.73 final drive ratio, transmission torque converter lockup control, a 2-inch lift and standard 33-inch tires on 17-inch beadlock-capable wheels.
The result is the most capable Jeep Wrangler ever with 10.3 inches of ground clearance; improved suspension articulation and maneuverability; approach, breakover and departure angles of 44.5, 22.6 and 37.5 degrees, respectively; and the ability to traverse up to 32.5 inches of water.
Jeep engineers put it to the test: the 2021 Jeep Wrangler Rubicon 392 confidently climbs up and down steep grades with minimal throttle and brake input.
“This is the most powerful, quickest, most capable Jeep Wrangler we’ve ever built,” said Jim Morrison, Head of
Jeep Brand – FCA North America. “The factory lift and abundant low-end torque from the V-8 makes the Rubicon 392 the king of the hills, whether you’re rock crawling at low speeds or powering up an incline. And, when pavement replaces dirt, Rubicon 392 makes quick work of the road.”
The 2021 Jeep Wrangler Rubicon 392 goes on sale in the first quarter of 2021.
Peak Power, Plenty of Torque
The addition of the 6.4-liter (392 cubic inches) engine marks the first time in nearly 40 years a V-8 has been a factory option for the Wrangler. Tuned specifically for the Jeep Wrangler Rubicon 392 and its functional hood scoop, the engine is rated at 470 hp and 470 lb.-ft. of torque.
Critical to on- and off-road performance, nearly 75 percent of the Wrangler Rubicon 392’s peak torque is available just above engine idle speed; this delivers exciting performance, whether enabling a 4.5-second 0-60 mph time or crawling up steep grades.
The performance of the 6.4-liter V-8 is based on a cast iron cylinder block and aluminum heads, accented with an active intake manifold, variable camshaft timing, twin spark plugs per cylinder, sodium-filled exhaust valves, hollowstem intake valves and piston oil cooling jets. The Wrangler Rubicon 392 engine is fitted with a rear-sump oil pan, high-mount alternator and free-flowing exhaust manifolds.
Fuel Saver Technology with cylinder deactivation seamlessly shifts to smooth, high-fuel-economy four-cylinder mode when engine loads are light, such as cruising on the highway. A tank-mounted high-performance pump keeps the V-8 fueled under even the most demanding conditions.
A functional hood scoop feeds the Wrangler Rubicon 392’s engine with cool, denser, outside air, which leads to enhanced performance.
Jeep engineers ensured the Wrangler Rubicon 392’s V-8 gets fresh air, regardless of the terrain and weather. The Wrangler Rubicon 392’s Hydro-Guide™ air intake system includes a tri-level ducting system with a series of drains, including a one-way drain in the air box that separates water – up to 15 gallons per minute – away from the engine’s incoming air. This enables the Wrangler Rubicon 392 to traverse water up to 32.5 inches deep worry free, even if a bow wake washes over the hood.
Should the Wrangler Rubicon 392’s functional hood scoop become restricted by snow, mud or debris, a secondary air path within the hood structure feeds the engine, making it possible for the Wrangler Rubicon 392 to reach top speed even with a fully blocked primary air path.
An active dual-mode exhaust is standard to deliver an exhilarating and unmistakable sound. The system engages automatically, opening valves in the exhaust system, under higher engine loads to reduce exhaust back pressure. The driver can also activate the system with the press of a button. The dual-pipe performance exhaust system is finished off with unique quad exhaust tailpipes.
Geared for Performance
A high-torque capacity TorqueFlite 8HP75 eight-speed automatic transmission delivers quick, crisp gear changes during both normal and performance driving conditions. This transmission also enables the driver to change gears via the new steering wheel-mounted aluminum paddle shifters, a first for the Jeep Wrangler, or the Electronic Range Select shifter.
The fully electronic, eight-speed automatic transmission features on-the-fly shift-map changing. The sophisticated transmission software relies on several input parameters to determine the appropriate driving conditions and adjusts shift pattern in response. The result is automatic shifting ideally attuned to the performance requirements of almost any driving demand.
The transmission’s gear ratios afford the right response at the right time, from crawling over obstructions on the trail to smooth power delivery at highway speeds, a product of smaller ratio steps between the gears.
The Wrangler Rubicon 392’s powertrain calibration includes Torque Reserve and AMax shifting, accessible when doing a brake torque launch, that delivers maximum acceleration for solid-pavement launches. Torque Reserve, an engine strategy used by drag racers, manages fuel flow to the cylinders and controls spark advance or retard to balance engine rpm and torque to maximize power delivery and launch performance. AMax shifting, a performanceenhancing strategy used on the Jeep Grand Cherokee Trackhawk, maximizes forward torque by coordinating shift time and engine torque management.
Paved Road Power That’s Ready for the Rubicon
The Jeep Wrangler Rubicon 392’s drivetrain puts the power down to all four wheels, all the time.
The heart of the driveline is a Selec-Trac full-time, active transfer case with a 2.72 low-range gear ratio. The transfer case has four driver-selectable modes: 4WD Auto, 4WD High, Neutral and 4WD Low. This full-time two-speed transfer case is intuitive and allows the driver to set it and forget it, while constantly sending power to the front and rear wheels. The Selec-Trac transfer case also allows for Wrangler Rubicon 392 to be flat-towed.
Off road, the Wrangler Rubicon 392 delivers the legendary capability Jeep is renowned for. This includes:
Off-road Plus with Sand and Rock modes: The push of a button maximizes the Jeep Wrangler Rubicon 392’s tractive capabilities. The modes adjust throttle, transmission shift points and traction control for peak performance on higher speed passes on sand terrain, as well as during low-speed rock crawling.
The Off-road Plus drive mode also gives drivers the ability to lock the rear axle at high speeds while in “4H”
Selec-Speed Control manages vehicle speed in "4L" while traversing off-road terrain without requiring throttle or brake input. Selec-Speed Control is activated using a button on the dashboard and can be adjusted from 1-5 mph simply by using the Electronic Range Select shift control.
The Wrangler Rubicon 392 masters low-speed downhill descents by using the 6.4-liter V-8’s engine braking, revised transmission torque converter lockup control and a 48:1 crawl ratio to manage vehicle speed without the driver needing to use the brake pedal.
Durable Frame for the Most Powerful Wrangler Ever
The Jeep Wrangler Rubicon 392 chassis includes upgraded frame rails, front upper control arms and cast iron steering knuckles to take full advantage of the Wrangler Rubicon 392’s power and torque. Heavy-duty brakes bring the Wrangler Rubicon 392 to a composed stop no matter the terrain.
The Wrangler Rubicon 392’s off-road prowess flows from wide track, heavy-duty Dana 44 front and rear axles with thicker axle tubes and Tru-Lok electronic locking differentials. An electronic front sway-bar disconnect maximizes suspension travel for the most demanding off-road conditions.
Augmenting the Jeep Wrangler’s proven five-link front and rear suspension, the Wrangler Rubicon 392 comes with a 2-inch factory lift and is fitted with specially-tuned high-performance FOX aluminum monotube shocks to maximize handling and comfort.
Bronze Identifies Something Special
The 2021 Jeep Rubicon 392 keeps to the original design theme of Wrangler with bold and functional cues, a wide stance and its recognizable trapezoidal wheel flares. The factory 2-inch lift adds to the vehicle’s character and presence.
The Wrangler Rubicon 392 carries bronze accents to mark the most powerful Jeep Wrangler ever. Bronze traces “Rubicon” on the hood, covers the front and rear tow hooks, and FOX Shocks’ decal outline. It also outlines the Jeep badge and the Trail Rated badge.
Adopted from the Jeep Gladiator Mojave, a 40-mm raised hood with aggressive appearance and a fully functional hood scoop provide cold air intake and greater water fording capability. It also carries a “392” badge on each side, signifying the most cubic inches ever offered in a Jeep Wrangler.
The grille design delivers greater airflow and cooling of the 392 V-8.
Bronze wheels measure 17 by 7.5 inches and are beadlock capable with an optional black locking ring available through Mopar.
The leather-appointed interior includes unique bronze stitching. The leather seats with Rubicon 392 nomenclature keep drivers comfortable with performance-inspired, integrated upper bolsters to hold occupants in place. To accommodate new engine specs, the gauge cluster receives all-new numbering and design. Available on the Jeep Wrangler for the first time, the leather-wrapped, performance steering wheel features wheel-mounted paddle shifters for fast access to the eight-speed transmission and management of 470 lb.-ft. of torque.
The Uconnect system projects on a standard 8.4-inch screen. Loaded in the software, Jeep Off-road Pages allow owners to monitor pitch, roll, altitude, GPS coordinates, drivetrain power distribution and more.
The 2021 Jeep Wrangler Rubicon 392 is available in nine exterior colors: Black, Bright White, Firecracker Red, Granite Crystal Metallic, Punk ’n Metallic, Sarge Green Metallic, Snazzberry Metallic, Sting-Gray Metallic and Billet Silver Metallic, all with a black interior.
The 2021 Jeep Wrangler Rubicon 392 includes 11 premium features, normally options on Jeep Wrangler:
Leather interior
Infotainment Group
Body-color hard top
Body-color flares
Steel Bumper Group
LED Lighting Group
Cold Weather Group
Safety Group
99mph due to the tiresWhat’s the top end?
The link isn’t working...?
Punk'n Metallic isn't a true metallic, despite the name. The flake in the paint is from glass and it's very subtle—looks flat until you see it up close in the sun. I love it!I edited the cliff notes for you !
In all seriousness - thanks for the quality info and pics - looks (and sounds awesome). Any driving impressions you can share?
All colors are metallic? Metallic Punk’n or Sarge sure sound interesting.
It's 2021. Reasonable prices are a thing of the past. Welcome to a two class world; those who have it and all the other meat.if it can be had at a reasonable price.
BEST QUOTE OF THE THREAD! WELL DONE SIR!"TorqueFlite Eight-Speed Automatic Transmission w/ paddle shift"
No sale.
I've never owned a vehicle with an automatic and never will.
That's a liberal hate concept.presence
I also have a fast car (Porsche 911) for going fast, so it's not an expectation from my Jeep.How many of you guys who already have another fast car are going to get this 392? I have a 3.6 JLUR and a fast car and I keep waffling.
