Adventure.AS
- Jun 16, 2019
- Port Dover ON Canada
- 2020 JLUR
I received this notice from GasBuddy. Not sure why it will take until March 14 for the recall to begin.
Recalls - 1 Found
SUSPENSION:FRONT:CONTROL ARM:LOWER ARM
The improper weld may allow the lower control arm to separate from the axle which can increase the risk of a crash.
NHTSA Campaign Number: 20V042000
Components: SUSPENSION:FRONT:CONTROL ARM:LOWER ARM
Summary
Chrysler (FCA US LLC) is recalling certain 2020 Jeep Wrangler vehicles. The left side lower control arm bracket and weld may not be correctly positioned.
Remedy
Chrysler will notify owners, and dealers will inspect the front axles, replacing them as necessary, free of charge. The recall is expected to begin March 14, 2020. Owners may contact Chrysler customer service at 1-800-853-1403. Chrysler's number for this recall is W01.
Notes
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov.
More details via Allpar:
Around 3,005 U.S. 2020 Wranglers are being recalled because the lower control arm bracket and weld might not be in exactly the right spot (up to 12 mm off), bringing the risk of lower control arm separation and loss of steering.
As one might expect, the recall is international in scope. Only around 10% of Wranglers built during the suspect period (July 22 to October 26, 2019) are affected.
The problem was not human error or engineering, but a broken welding fixture used by supplier Dana. The investigation started on October 15, when FCA Quality investigated four front axles with separated left-front lower control arm brackets sent in after warranty repairs. Later that month, Dana verified the problem: because the machine might have held the control arm in the wrong place, the weld may not have penetrated and held the axle tube to the bracket.
There have been five warranty claims and no injuries related to this issue, according to FCA. The axles can be part numbers 68294136AJ, 68294135AJ, 68294375AJ, or 68294356AJ. Owners who paid for work themselves can get reimbursed; otherwise, if the dealer finds the problem, they will get a new front axle.
Recalls - 1 Found
Summary
Remedy
Notes
