2020 Sport S (3.6L/Auto) gearing question, moving from 245>285 tires
donmontalvo
Don
Plano, TX
donmontalvo.com
2021 Jeep Wrangler Unlimited Rubicon (Snazzberry)
Systems Engineer
I'm having a 2.5" lift and 285/70R17 tires installed this week.
I've been trying to read up as much as possible on all things Jeep. :)
ExtremeTerrain says my front axle is a Dana 30, and my rear is Dana 35:
https://www.extremeterrain.com/wrangler-jeep-axle-identification.html
Stock gearing is 3.45, whereas Rubicon (which has 285s) comes with 4.10.
Am I looking at re-gearing for the 285 tires, if needed/possible with the OEM axles?
[UPDATED with Dana info from Extreme Terrain]
jessedacri
Jesse
Los Angeles, CA
2019 Bright White 2dr JL Rubicon 3.6
Nah you'll be more than fine on 285s. I'd venture up to 295s even, but also note you can pick up a set of five 285 KO2 Rubicon takeoff wheels+tires in near-new condition for just under $1k all in pretty often but you definitely have to be willing to wait sometimes for a set to come up in your area. Lots of Rubicon owners upgrade fast. Plenty of people on here running 35s on the stock sport/sahara gearing too, but you'll feel them.
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Yep, no issues with 285s on a Sport. I did the same swap a couple months back. You will want to get something like a Tazer or the JScan app to set your new tire size into the Jeep's computer so the speedometer will display your correct speed.
jeepoch
Jay
Longmont, CO
2019 JL Wrangler Sport S 3.6L Auto 2 door, 2.5" lift, 35s
Don,
You'll be fine. I went with 35's on my Sport S 3.6L Auto. I'm loving this set up with a Mopar 2.5" lift. Drives great both on and off-road. The only issue is that I rarely see 8th gear anymore. Not a problem since you can always manually request 8th. However, with 285's I'll bet you won't notice any change at all.
You'll certainly have no problems. I'm not, even on bigger tires. Here are some pics to show that if 35's (315s) work, so too will 285's as well. You'll like em.
Jay
donmontalvo
donmontalvo
Don
Plano, TX
donmontalvo.com
Systems Engineer
I went to Moab for a couple weeks and to be honest couldn't really tell the difference.
https://donmontalvo.com/2020/08/17/moab-aug-12th-thru-16th/
However not seeing 8th gear makes me want to upgrade my gearing to 4.10 at least.
I do plan to move to 35" tires in the Spring, so changing the gearing seems to make sense.
donmontalvo
donmontalvo
Don
Plano, TX
donmontalvo.com
Systems Engineer
I ended up moving to Dana 44s (M210/M220) with lockers and 4.10 gearing, still using the 285/70R17s that I mentioned in the first post.
I then bought a used set of 35x12.5x17 Pro Comp (steel) wheels with Nitto Grappler MT tires.
I'm planning on a 3-4 week trip from PA to Moab>Rubicon and possibly Big Bear before coming back.
Thanks for all the info guys!
