n2jeep
Just installed Mopar lift 3 days ago with larger wheels & tires, along with OE Fox stabilizer. Steering is still good, but it does seem to be a little harsher ride when you hit bumps and road imperfections. My caster is around 4.1 , and my axle on the front is off center by 1/2" or so. I've ordered geometry correction brackets and a steersmarts XD ADJ Trackbar. Also my tire pressure is around 41psi, which lowering may help when you hit bumps. Overall Jeep drives good and I could live with it without adding the parts I've ordered. But its my 1st jeep and I might have a new addiction.
20x10 Method 605
325-60-20 Nitto Ridge Grapplers ((Went with the size tire since it's a little bigger then a 35x1250x20))
JW Speaker Headlights
20x10 Method 605
