NPE102414
- Peter
- Aug 5, 2019
- Pelham New Hampshire
- 2020 JLUR
Please post up the sheet they give you at the alignment shop. Tire pressure is so important on a wrangler. I actually carry a Milwaukee 12v tire inflator and a good dual tire pressure gauge in my Jeep because I constantly monitor my tires. You should have about 36psi in your tires as a starting point and go down from there until you find the sweet spot. No 2 Jeeps Dr. the same with the same tire pressure because the weight of the jeep and passengers/cargo plays a role as well. Always check and fill your tires when they are cold, never during a trip or when you just got back from a drive. The best time to do it first thing in the morning before you leave for work.thanks for the help! for getting the degrees I used an app, I hope I did something wrong if it is something hard or impossible to fix. Bubble level is the pinion angle, plumb line is the caster angle that I got from app. On Monday I will take the car to the Tire Alignment shop for getting exact angles
