Haven’t had a chance to check the right side yet. Will do in a little while.Do you have one under the right side cowl?
The wiring diagran shows an ASSY PDC AUX connector on the left hand side. There are upfitter connections for companies to add devices. Might be one of those.
If I remember correctly, this connector was mentioned on the forum in the past and the connector is not for Aux lights nor can it be used for same. We'll see if I my memory serves me right.I seen that too and wondered what it was.
I'm in to find out.
well technically... if you find the other end and cut them, you can use them for anything you want (assuming they handle the load). wire is wire.the connector is not for Aux lights nor can it be used for same.
@Dave928well technically... if you find the other end and cut them, you can use them for anything you want (assuming they handle the load). wire is wire.
