2020 JL No ACC/RUN and power lock don’t work
Thatjeepguy
Jacksonville
2020 wrangler jl sahara 2.0
Hi everyone.
I have a 2020 wrangler jl unlimited Sahara 2.0 and have a couple of problems.
Firts one is the Ignition won’t go from Off to ACC or RUN. All the Interior or exterior l ligts are working, ignition switch is lit. I changed the keyfob battery, tried pushing with keyfob but nothing; it stays on OFF.
Second one is the power locks don’t work. When I want to lock or unlock using keyfob I hear clicking noise from BCM, exterior lights flash and horn goes off. Anti theft is also active (they activate when I open a door) but doors won’t lock.
I’ve checked the fuses, connections, can bus connections if they are loose, replaced the battery, finally switched the fusebox but no luck so far. My jeep doesn’t run on secondary battery so it’s not that.
I am open to any suggestions. Thanks
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Have you tried disconnecting the battery to let the computer clear and then reconnect it and see if issue persists? I think it is like 30min to leave disconnected.
Thatjeepguy
Jacksonville
Yes I have but nothing changed
