2020 JL EcoDiesel Dyno Run
rickinAZ
Phoenix
Allowing for drive train losses, the bhp is right on, but the torque is a little short.
HP: 218.33 @ 3680 RPM
TQ: 347.35 @ 3190 RPM
4th Gear
JLURD
Alaska
2018 Compass Latitude 6MT, 2020 JLUR 3.0
Considering the Ram 1500 3.0 puts out 480, a simple chip tune will solve any torque deficit.
rickinAZ
rickinAZ
Phoenix
Someone has edited my post twice: changed the title (from "dyno run"), and added the bhp/torque grid from 4th gear. Not that I'm complaining about the changes, but I'm concerned that someone (moderator?) is adding to MY posts - I should be the only one who can change them.. Seems very odd (and...inappropriate).
BuffaloBill
WI
2018 Wrangler, 2014 Ram 1500 EcoDiesel 2020 JLUR Ecodiesel
That is kind of weird. I'm also interested in hearing the answer.
JAY
Administrator
Staff member
Administrator
Jay
Wrangler
Admin
Yes, we add to posts/threads as appropriate to add helpful information. Particularly if they're featured on the homepage.
Compression-Ignition
Roy
Montana
I'd like to know what model dyno, and if 4th is direct in the 8HP75. I've been looking for the gear ratio's in this trans, and can't seem to find them published anywhere.
rubileon
Water over dirt planet
JLUR RHD 3.6
Which is precisely the reason why absolute numbers from dynos shouldn't be taken too seriously.
What ever is being compared for hp/torque has to be dynoed on the same dyno at nearly the same time and it has to be done a few times because there's also heat soak.
Gorilla57
Chandler AZ
2019 JLUR Mojito
6th gear is 1:1 and there are charts on Allpar website that show gear ratios.
thance
New Jersey
2010 Commander, 2002 Liberty, Looking for JLURD
Was traction control completely disabled?
No IFS
So Cal
JL Rubicon
Thank you for posting trans gearing.
Also curious why they dyno pulled in 4th gear ?
WXman
Central Kentucky
2018 Wrangler Unlimited
That torque curve doesn't make sense at all. And, it doesn't match the curve FCA showed for the 3rd Gen EcoDiesel during press launch. I'm very skeptical of this video.
But thanks for posting. Good to see that companies are working on things.
beaups
Sean
Ohio
2020 JL
Wouldn’t the 4th gear ratio of 1.67 increased torque verses the 1:1 ratio?
No. Dynos measure torque at the wheels and calculate it back to engine torque based on engine RPM alone.
