twa8000
Just picked up this 2019 that was under water (Freshwater) for nearly 90 minutes. I’m in the process of totally cleaning and restoring all the electronics at the moment. I will continue to update this thread along the way if there is interest in the project.
Mechanical Items water check.
HAD WATER IN IT
HAD WATER IN IT
- Engine
- Front Diff
- Transmission
- Rear Diff
- Transfer Case
- TIPM (Fuse Box) - Bad / Replaced
- BCM (Body Control Module) - Bad / Replaced
- PCM (Powertrain Control Module) - Good
- ABS (Anti-Lock Brake Module) - Good
- IPC (Instrument Panel Cluster) - Bad / Replaced
- TPM (Tire Pressure Module) - Good
- TCM (Transmission Control Module) - Good
- ORC (Airbag Module) - Good
- RFH (Radio Frequency Hub) - Bad / Replaced
- EPS (Electronics Power Steering) - Good
- PTS (Parktronic System) - Bad / Replaced
- OCM (Passenger Seat Module) - Good
- HCP (Hybrid Control Pack) - Good
- SCCM (Steering Column Control Module) - Bad / Replaced
- ESM (Electronics Shift Module) - Bad / Replaced
- DTCM (Drive Train Control Module) - Bad / Replaced
- BPCM (Battery Pack Control Module) - Good
- DPDM (Driver Presence Detection Module) - Good
- SGW (Security Gateway Module) - Good
- DASM (Driver Assistance System Module) - Good
- ASBS (Automatic Sway Bar System) - Good
- HVAC (Heater Vent Air Conditioning) - Bad / Replaced
- CMCM (Radio) - Bad / Replaced
- HSCM (Heated Seat Control Module) - Bad / Replaced
- RBSS (Right Blind Spot Module) - Good
- LBSS (Left Blind Spot Module) - Good
- ICS (Integrated Center Stack) - Bad / Repaired
- AMP (Radio Amp) - Bad / Replaced
- PTCM (Power Top Control Module) - Bad / Replaced
