xj884x4
- Jordan
- Sep 26, 2018
- Greensboro, NC
- 78CJ5, 88XJ, 97ZJ, 02WJ, 04WJ, 05TJ, 19JLUS
I ordered a 2019 Sport S without anti slip.
My build sheet says "Dana M220 Rear Axle" and my window sticker says "3rd Generation Dana® 44 HD Rear Axle".
Pretty happy about this unannounced change.
EDIT: After looking at a bunch of '19 build sheets it looks like M220 is standard now but gets replaced with M200 when ordering automatic transmission and not having the anti slip package
I didn't see your post. It is consistent with what the order guide says. Talk about confusing!I posted a few days ago:
Yeah I posted it in the axel thread when I noticed it. I was fairly surprised/happy when I realized I had M220 at no added cost.I didn't see your post. It is consistent with what the order guide says. Talk about confusing!
When I ordered my manual 2018 they required the DSA, which included M220. So there is something going on there.
You got a manual Sport S?Yeah I posted it in the axel thread when I noticed it. I was fairly surprised/happy when I realized I had M220 at no added cost.
Ok. That's not bad. But according to the order guide there is no way to get the M220 with the automatic even with the DSL. That is different than the past. May be a typo but needs clarification.I think what’s going on here the sport jeeps come standard with a manual transmission so they come standard with a Dana 44 / m220 rear axle if you get the optional automatic then you get the optional Dana 35 / M200 open. The Sarah trim level comes standard with the dana44 /m220 regardless of transmission option. Rubicon all m220 wide.
That is correct. Manual Sport S no anti slip but M220You got a manual Sport S?
I think you are correct about the Sport. I’m looking at a window sticker for a 2019 Sport JL with auto. It lists the D44 as standard but under options it lists 8 speed auto transmission and 3rd Generation Dana Solid rear axle.I think what’s going on here the sport jeeps come standard with a manual transmission so they come standard with a Dana 44 / m220 rear axle if you get the optional automatic then you get the optional Dana 35 / M200 open. The Sarah trim level comes standard with the dana44 /m220 regardless of transmission option. Rubicon all m220 wide.
Thanks. Will do but the site seems to be disabled.You should check the build sheet it will be clearer there.
Doh!Thanks. Will do but the site seems to be disabled.
https://jeep.custhelp.com/app/jeep/eqlisting_detail
