2019 JLU dash display lights go dark/nav display too
2mnycars
Canada
JLU
It's frustrating.
It has happened a number of times.
It even happens when when we use the windshield wipers sometimes. And at night driving the dash becomes very dark suddenly, without the driver changing anything.
We try to increase the brightness using the switch on the dash. If we turn the dome light on, we can adjust the switch down a little--but it's too bright.
The Jeep has been back to two dealers for this to no avail.
I hope that someone can shed some light on this so we can get it fixed.
Thanks
2mnycars
2mnycars
Canada
JLU
Clarifying...when we're driving the JLU Wrangler (2019) sometimes the lights on the dash go dark
When this happens at night we can't see anything on the dash at all! The dash lights were fine, then all of a sudden the display goes dark. We haven't touched a thing.
We've had two service visits. First one the tech pointed out the switch used to brighten dash lights. If we turn it FULL BRIGHT and the dome light comes on, then notch it back just a bit, the dash lights are bright--way bright.
It's frustrating.
2mnycars
2mnycars
Canada
JLU
Got the Wrangler new September a year and a half ago.
Talked to the dealer about it. They showed us the dimmer switch for the dash lights. Thanks.
Not the first car or 4X4 we've had. Had too many cars.
Dash Lights go dim at night....not often. But it's a pain in a tender spot every time.
Next oil change we'll mention it again. And the dead spot in steering, even though the steering gear was replaced.
2mnycars
2mnycars
Canada
JLU
Still have this problem.
It was reported to the dealer several times.
Dealer didn't help. "It's a Jeep Thing"
Someone suggested going into U Connect settings. Did. Turned off the setting that turns the lights on when wipers start. No change. Didn't work.
It's a safety thing. I'm concerned.
DadJokes
Daniel
Kentucky
Sahara
That’s not normal. There’s no “Jeep thing” to it. I’ve not heard of this happening unintentionally outside of the screen off button or turning the infotainment off.
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU Sport
Sounds to me like it might be the switch itself, like the dimmer function is not working properly. That's where I'd start troubleshooting. Maybe suggest that to the service adviser or try a different dealer.
Smart Stop Start
