2019 Black Friday/Cyber Monday Purchases and Installs
SDhobbs
Del Mar, CA
2020 JLUR
EVO 3.5 Enforcer Stage 3 Plus lift
Rancho 9000XL shocks
EVO Tire carrier
Tazer Mini
Cooper STT Pros 37x12.5x17
Method Roost wheels
Purchased tires and wheels from local Discount Tire store 10% off total purchase
Everything else from Northridge 4x4 12% off
Discount is installing the wheels/tires and I’m going to EVO Offroad to have the the lift & tire carrier installed.
crbrenny
Chad
Palmetto, FL
2019 JLUR Sting Grey; 2021 JLR Gecko
Engineer
I grabbed a Warn winch and front D-ring points, Maximus-3 winch plate and rear D-ring anchor points, a Tazer mini, and BajaDesigns pro OEM foglight replacements. Pics to come. :like:
oceanblue2019
Maryland
2019 JLUR 2.0L Auto
Metrology
Rock Krawler JL25NL-4S1 suspension kit, CCM door-less mirrors, and Rokblokz mud-flaps.
Just need some 37" tires but since going on existing rims will source locally.
After that the Jeep is officially done as I've declared to my wife :idea:
crbrenny
Chad
Palmetto, FL
Engineer
Received my winch, plate, and closed tow loops today. I am disappointed in the finish of the Maximums-3 stuff, the winch plate has egregious areas missing paint, and the red recovery points have several areas where the coating has been marred off, I'd normally just paint it but I will have to reach out to them, one of my Zeon filler plates is slightly bent and the coating on it is cracking off, adn its a texture that will be hard for me to mimic.
OversandJL
Massachusetts
2018 JLUR, 2017 JKU Sahara, 2014 JKU Sport S, 2007 JKU Sport, 1997 TJ,
Upgraded my Tazer lite to a full Tazer mini for $65 (half price)
They also have a $100 off deal for a Tazer with the front camera kit.
Wish I saw the 50% off on the upgrade. I still need to do that.
Az-jewel
Julie
Southern Utah
aquajeepgirl.com
‘18 JLU Sport S
SAHM
Got a high lift jack and Hood mount (painted to match my Jeep)
Fire extinguisher and mount (also painted to match)
D-rings (being painted currently)
New front and rear bumpers from Doetsch off road, a local shop. Urban Krawler.
Badlands 12.5 winch from harbor freight.
99wishes
99wishes
2018 Jl Moab
RC rear cargo tray arrived. It is nice but doesn’t fit as well as I would have hoped. It’s a little more rigid than the all weather mats.
Just couldn’t get myself to buy the Quadratec version because of their hideous logo. Really that’s kept me from buying a lot of their stuff.
Still waiting for the good stuff to come in!
Carlton
Chicago
Jeeps lots of jeeps
I got around to installing the Fox ATS this week.
Install is pretty straight forward.
Remove 4 bolts: 3 bolts for the stock axle side bracket. 1 bolt at the tie rod.
Install supplied bracket to steering stabilizer.
Install bracket to axle.
Insert shaft end to the stock tie rod mount.
Torque to spec. Check clearance. Drive around and test settings.
I ran into a couple issues. The mounting points on the stabilizer were all oriented in incorrect directions when it arrived. I had to loosen the bolts, reorientate the mounts, then reinstall bolts with blue threadlocker. Not a big deal but think Fox would send them out correct in the first place.
Second issue was that the circular mount on the stabilizer did not fit in the provided bracket as it was designed to. I had to use a dremel to open it up.
I have attached pictures to show these issues. Fox quality control earned a failing grade lol.
The last issue is the small heads on the stock bolts for the axle side bracket. They don't mesh up well with a socket (proper size socket) and slip.
I test drove the jeep at a 10, 15, 20, and 25. The jeep now feels like a go cart steering. Definitely more stiff turning left and right which I like. The wheel does not self center on the higher settings. I don't mind this but others may.
Az-jewel
Julie
Southern Utah
aquajeepgirl.com
‘18 JLU Sport S
SAHM
Got my new front and rear bumpers: the Smittybilt XRCs. Installed last night with the Harbor Freight Badlands 12,500 winch.
still need to figure out the wiring on the winch, led lights and license plate lights...but they’re on!!
Very happy with them! Shout out to @doetsch off road for the bumper Black Friday deal!
jimbobbeg
New Mexico
2019 JLUR
Got my Rugged Ridge Venator bumper and Warn VR 10-s winch installed this weekend. Looks awesome!
Looks great! I just pulled the trigger on the bumper yesterday (on sale) and had purchased the same winch a couple of months ago when there was an introductory discount.
I see that the center top plate is stamped steel. Are the end sections stamped steel as well? I don't do any rock crawling but go to more remote areas in Southern Colorado to fish. So I'm not concerned that the bumper isn't super strong. I ordered "Jack" with plastic bumpers so I could pick my own.
