2019 2 Door Rubicon, Bikini - Discrete But Purposeful Build
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Sweet! Merry Christmas! I may be a bit biased though....
j4three
Memphis, TN
2017 JKU Sport, 2020 JL Willys
Wow, that's a great look!
I'm interested in this same Mopar lift as well but as others have stated, I'm concerned about the actual amount of lift that I'll get. Do you know the distance from the ground to the bottom of your rock rails?
JPAloha
JPAloha
Calgary
2019 JL Rubicon 2 door, 2022 JL Rubicon 4xE
Accredited Financial Planner
To the bottom of the rock rails (point nearest the body) it’s near enough 18”. To the bottom of the frame rails it’s near enough 15.5”.
JPAloha
JPAloha
Calgary
There was further progress this weekend...
Nothing too major...ARB diff covers front and rear & taking some inspiration from the upcoming Mojave edition a change to the front skid plate...
JPAloha
JPAloha
Calgary
Started plumbing in the front ARB breather kit.
Front axle and transmission lines extended. Axle breather raised about 8”, trans breather raised about 1.5”.
Still to do: Transfer case (will need some 3/8” hose as the breather currently sits 1.25” off the top of the T-case) & rear axle (running that to a separate ARB manifold that I plan to position behind the taillight).
JPAloha
JPAloha
Calgary
Bought a couple of feet of 5/16” transmission hose and installed the T-Case breather line.
I had to remove the factory skid plate to be able to get better access to the breather pipe which is right on top of the casing and a real pain to get to.
From there I ran the ARB supplied 8mm hose (via an adapter I made up to go from the 5/16 to the 8mm) into the engine bay, around the back by the firewall and around the drivers side fender to the ARB manifold. Approx. raise of 12”.
Later today I’ll finish up by putting a second manifold behind the passenger taillight and extending the rear axle breather line - should raise it by approx. 8”.
The manifold is mounted on a bracket I made and attached to one of the studs that mounts the ECM.
JPAloha
JPAloha
Calgary
Finished up the job today with the rear axle extender. The factory breather vent came off so I pushed the new fitment on and ran the ARB line over the frame rail and up behind the fender liner into the taillight housing area.
I added a pic of the factory fittings after they were removed - you can see how short the T-Case factory hose is and why it was such a pain to do.
Utilized a factory threaded stud to add a clamp to help guide the ARB line.
Made a bracket to attach the manifold to one of the tailgate hinge studs. Be mindful of the metal bar that moves in and out as you open and close the tailgate.
JPAloha
JPAloha
Calgary
My next few projects are lining up:
A Teraflex IR Adjustable Track Bar is on the way,
I found a pair of Warn D-Ring Mounts that got lost under a pile of my wife’s garage junk - I’ll have to see if those will work in conjunction with the Maximus 3 Stinger as I think they share a mounting location.
I acquired an extra set of dash panels that I’ll have painted, I’m almost decided on Bikini to match the bodywork but a Pearl White is still on my mind a bit. Am I committing sacrilege by painting a set of red dash panels? Lol.
4xFUN
Scottsdale AZ
2020 2-door Rubi. 2023 RAM TRX
Heck no, paint away! I have the leather w/red stitching in my stack of parts-just waiting till I finish suspension / steering which hopefully will be by this Friday.
JPAloha
JPAloha
Calgary
A quick shot after taking part in a cruise around a few local seniors homes.
Creeker
Hickory, NC
CJ-7, 2020 JLR
Good looking Rig!
What did you decide on the dash (paint, no paint)?
JPAloha
JPAloha
Calgary
Good looking Rig!
I’m mostly leaning towards Bikini - deciding if I should add another element to it or not.
JPAloha
JPAloha
Calgary
Today’s small job added some much needed under hood lighting.
KC Cyclones mounted up and wired to Aux 2. I debated where to mount them but ended up removing the first hood liner clip, drilling the 1/8 hole right next to it and using the gap in the liner to route the wires while the cyclone itself provides the support in place of the missing clip.
JPAloha
JPAloha
Calgary
