Torero
If the fuel injectors were completely closed and you are on an automatic, then the engine would quit running and you would not be able to restart it without using the starter. Since you cannot push start an automatic, I seriously doubt
you are dead wrong.If the fuel injectors were completely closed and you are on an automatic, then the engine would quit running and you would not be able to restart it without using the starter. Since you cannot push start an automatic, I seriously doubt that happens. Some amount of fuel must still be flowing.
For many of the vehicles that I've driven, if you let off on the accelerator, there is noticeable drag with an automatic. With a manual transmission, there is drag if you leave it in gear, but if you depress the clutch or put it in neutral, you are mainly just subject to wind drag (and rolling resistance from your tires). There's a bit of variation in the feel of automatic transmissions though... For example, back in the late 1980s, I was looking to buy a Porsche 928[S/S4]. I test drove a few of them, but every one the dealership got in was with an automatic. I hated them since when you let off on the accelerator, they did not have the drag of a manual that was still in gear. Sure, they had less drag than a manual in neutral, but it was entirely too little drag for how I tended to drive a sports car.
Google it. Even carburetors shut off fuel while in compression mode.
