York-Jeep07
Do you have to unmarry when you take your Jeep into the dealer? Inspections etc?Z Automotive.
https://www.zautomotive.com/shop/
Tazer JL will do everything Tazer Mini and Tazer Lite will do less.
Gregj
Gregj
See post above,I got the Tazer Mini directly from Z-Automotive.Which Tazer? And where did you buy?
The mini does everything.Z Automotive.
Gregj
Thank you both - will look at all options. Does the AEV ProCal do all of this as well or just tire size? If you know - I can also research tonight. ThanksThe mini does everything.
Ok that's a change, I see the Mini and the JL are the same price too.The mini does everything.
Hey, York-Jeep07. Although you are looking for assistance from fellow forum members, we also recommend contacting the dealer with this inquiry. Please let us know if you have any questions!I had the OEM halogen driving lights and turn signals swapped out by the dealer yesterday - after two return trips to the dealer - the lights are finally working, BUT can the dealer do a code to get the dash message for "turn signal lights are out" to not come up every time you turn on the jeep? Please advise. If it can go away - what is the code or how to remove. Much appreciated.
I did and they said adding a resistor will void the warranty. Is there a mopar resistor I can let them know about? The dealer is the one who did the install.Hey, York-Jeep07. Although you are looking for assistance from fellow forum members, we also recommend contacting the dealer with this inquiry. Please let us know if you have any questions!
Kate
JeepCares
To be completely honest - if I went by the dealer's advice it would be "do not modify your jeep at all". The forum members have provided better advice than the dealer. Doing a mod that is with Mopar parts and getting issues does not seem like good customer support. If not for the information from the forum - I would have driving lights that do not work at all. I can understand error codes for non OEM parts, but for OEM parts to have issues is crazy. Dealers do not even understand how to do the sale codes for 35 inch tires to get the speedo to calculate correctly? Love the jeep, just wish the support was better considering the amount of money spent in added accessories.Hey, York-Jeep07. Although you are looking for assistance from fellow forum members, we also recommend contacting the dealer with this inquiry. Please let us know if you have any questions!
Kate
JeepCares
I understand, York-Jeep07. With that said, if you have any inquires in the future, don't hesitate to reach out.To be completely honest - if I went by the dealer's advice it would be "do not modify your jeep at all". The forum members have provided better advice than the dealer. Doing a mod that is with Mopar parts and getting issues does not seem like good customer support. If not for the information from the forum - I would have driving lights that do not work at all. I can understand error codes for non OEM parts, but for OEM parts to have issues is crazy. Dealers do not even understand how to do the sale codes for 35 inch tires to get the speedo to calculate correctly? Love the jeep, just wish the support was better considering the amount of money spent in added accessories.
What do Jeepās engineers say? Do the resistor - is there a different sales code to use? Or would they say it is not meant to upgrade to OEM LED lights? Thanks for the help.I understand, York-Jeep07. With that said, if you have any inquires in the future, don't hesitate to reach out.
Kate
JeepCares
Worked through a similar process; after spending an insane amount of time and effort pursuing a sales code solution I concluded there isn't one.. (apparently the wiring from the turn signal to the BCM is different)What do Jeepās engineers say? Do the resistor - is there a different sales code to use? Or would they say it is not meant to upgrade to OEM LED lights? Thanks for the help.
Tim
Thank you. Was wondering if the resistor would work or not. The dealers have been no help at all. Thanks for the reply. Once the wife gives the ok - I guess I will purchase the Tazer mini. ThanksWorked through a similar process; after spending an insane amount of time and effort pursuing a sales code solution I concluded there isn't one.. (apparently the wiring from the turn signal to the BCM is different)
I then tried the resistor solution.. it didn't work either so I bit the bullet and purchased a Tazer J which fixed the issue.. in retrospect I'd purchase the Tazer Mini (instead) as functionality is identical but the Mini installation is much cleaner and leaves the OBD port open..
I am unable to speculate, York-Jeep07, I apologize. I do recommend connecting with your dealer though to discuss options.What do Jeepās engineers say? Do the resistor - is there a different sales code to use? Or would they say it is not meant to upgrade to OEM LED lights? Thanks for the help.
Tim
Kate,I am unable to speculate, York-Jeep07, I apologize. I do recommend connecting with your dealer though to discuss options.
Kate
JeepCares
