2018 JLU Aux temporarily unavailable battery charging
Crystalee
Crystal
Temple TX
Jeep JL Wrangler Unlimited
Had my screen replaced at the dealership due to delamination and now at times when I crank my Jeep it reads aux temporarily unavailable battery charging. Could it have been something the dealership did when they replaced the screen? I have nothing extra hooked uP to my AUX. Should I take it in to get looked at? Anyone else seen this?
rubileon
Water over dirt planet
JLUR RHD 3.6
This is the problem with factory features. They nanny you. It's better to go aftermarket whenever possible.
Crystalee
Crystalee
Crystal
Temple TX
It’s still under warranty so no aftermarket work was needed.
MORTON
JLU
To answer your question more directly, yes, you should take it in. They may need to perform another flash to correct the issue. This should be at no charge to you. Should take sub-30 mins once it’s in the bay.
EDIT:
I would also ask about the voltage of your battery. So that they are checking both the flash data they used to update the head unit and your battery. 2 birds with 1 stone.
MORTON
JLU
Really sounds like it’s either the flash or a battery that’s low.
Im leaning towards a battery that’s low as that message I believe is from the battery sensors.
But it won’t hurt to have them check the flash. If you hadn’t had the head unit recently replaced I wouldn’t even mention flash data and just went straight to the batteries.
They will likely check one of the batteries first though and I bet that will be where the issue is.
Crystalee
Crystalee
Crystal
Temple TX
EDIT:
Thank you, taking it in this morning. I will ask about that.
MORTON
JLU
Just really make sure they check the batteries. That should be your number one concern. I only mention flash data as you recently had your head unit replaced. Batteries again should be your chief concern. Wouldn’t want to be potentially stranded.
MORTON
JLU
Dkretden
Denver, CO
2020 JLUR 3.6L
My 2020 3.6L does this half the time I get in it. There are a number of threads on this. Bottom line, the ESS sucks. It is truly awful.
that said, OP, bring it into your dealer. I did. They May have to keep it over night to run some kind of “long“ test on the batteries. Mine did. “Nothing wrong. Works as intended”....... yep, ok ess tells me it’s not working half the time and there’s nothing wrong..... GREAT system.
i now press the start button and then immediately press the ESS OFF button and try to forget about a $60k vehicle that had 12 year olds engineer the ESS That saves FCA money on CAFE fines and costs me headaches.
Crystalee
Crystalee
Crystal
Temple TX
aldo98229
Aldo
Bellingham, WA
2018 Jeep Wrangler Unlimited Sahara, 2018 Fiat 124 Spider Abarth
Market Research
Dealers disconnect the battery for everything, even to replace a light bulb. Chances are they disconnected the battery to work on the head unit.
It could be something as simple as a loose battery terminal.
Good luck.
Punjabi New Yorker
Suffolk County, NY and Punjab, India
2012 Mahindra Thar (in India) - 2.5L Diesel, 4x4, 5 spd Manual ; 2020 JLU Rubicon (in USA) - 3.6 Gas with 8 Speed Automatic
Family business in India and USA (dual citizen of both)
I did come across this earlier as well, to the dealership now I’ll let you guys know what they do! Thank you for your advice guys.
Do you have the 3.6? I have had a similar issue but they went away by itself. You can thank the ESS and it's aux battery for that one I have been told. I now always turn it off whenever I get in. Recommend you do the same. Won't be surprised if FCA needs to to a TSB or a Recall due to the ESS down the road. Nearly $60k vehicle with a questionable ESS just so that the tree huggers in the government can be satisfied. Bravo FCA and EPA :facepalm:
Crystalee
Crystalee
Crystal
Temple TX
Yes I do have 3.6. I completely agree I could do without having to turn it off every time I crank it as well! Still haven’t heard back from the dealership but I’m hoping it’s just a simple fix.
Rubitrux
