So the oil pump is tricky
There is spring loaded sprocket
Took me a while figure out
I had to put Allan key to hold the balance shaft and then tighten the bolts to to make it work
hi , did you put it back together ? how is the engine running ? ran into the same situation ( 18 wrangler jl sahara 2.0 hybrid with low miles and broken engine from copart )
