HHGadget
- Gadget
- Aug 23, 2018
- Los Angeles
- 2018 JLU Rubicon
Hello all, I mostly lurk and rarely post. I am not the kind of person to complain on the forums and generally (and gratefully) search through others posts here to see if my issue is opoerator error or if there are simple, easy solutions rather than complaining or whining.
That being said i must say that I am at my wits end with the electrical issues I have had with my 2018 JLU Rubicon.
The dealer has replaced both batteries 3 times (on top of me getting sick of dealership waits and just replacing them myself - so 4 sets of batteries).
I have had the rear window defroster separate 3 times. The first two time i had the dealership repair replace, the 3rd time i took a tip from this forum and got the correct material (cant remember what it was) to sand and reattach the defroster button myself, then supported it by adding a dolop of silicone caulk a few inches down the line to remove stress).
There have been the multiple recalls (I get it, it was a first year model so I went in eyes wide open on that).
But... the amount of time i have been to the dealer in an around the electrical problems is now just beyond acceptable. Aside from the multiple batteries mentioned above (all related to ESS dash warning issues) and finally convincing the dealer the issue was the Alternator (they finally caved after vist 3 - each one taking a few days to more than two weeks to be serviced)
Just this morning, I had the car stop accelerating on the freeway (while trying to merge) and though i was fortunate enough to get off an onramp, she stalled in the middle of the offramp intersection and went into the "death start cycle" where you go to start, the dash lights up like christmas throwing warnings so fast at you that you cant read them, all while the strater seems "stuck" turning, like the old days when you held the key in the ignition to get the starter to turn.
The lights on the Automatic Shifter started blinking and i was unable to even get it in Neutral.
So, I physically switched the lever to park (indicator was flashing so i assume the shifter moving didnt actuall cause the transmission to do anything) and then got out and started rocking it back and forth as hard as I could (which wasnt much). Then i jumped back in and got it to start.
Drove out of the now snarled intersection and down some side streets gently.
The car ran completey fine after that, however I had a CEL so I got her home and checked the code.
P0007. A generic codse indicating voltage issues between the ECM and the fuel cut off valve.
The funny thing is, when I was having the (previously mentioned) battery / ESS / Alternator issues, the car did the exact same thing to me on another off ramp.
This behaviour makes me nervous to drive, what is supposed to be one of the toughest, off the lot offroaders, afraid to drive it on surface streets. Forget about going off road.
At least you can get towed off a street stall. Not always the case on some of the trails I (used) to go on.
My JLUR has 33K miles on it and it is hands down my favorite Jeep so far... when it works.
But off all the cars I have ever owned, this one has been the most unreliable, with the worst dealer support I have ever had.
I have emailed FCA on this, (they were the ones to nudge the dealership to finally fix (i thought) the issue, the alternator).
I love my JL wrangler and would keep this car forever, if only i wasnt nervous it wasnt going to strand me or put me in danger by "shutting down / freaking out" while driving it.
I certainly see why the manual version would have been a safer call.
Sorry just had to vent. I dont normally complain on a forum, just beyond frustrated at this point.
