2 Options for Third-Brake Light from Oracle Lighting
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Looking for a new third-brake light for your Jeep JL? Oracle Lighting has two options that are less than $70 (before your forum discount using the forum10 code!) and will fit your needs. Check them out below and drop us any questions you have!
Option #1: 3rd Brake Light Ring
Using our popular aluminum wheel rings and our industry-standard 2835 LED illumination, you can add a fully-functional 3rd brake light ring to your Jeep. The extended brackets mount to the spare tire carrier and the wiring is easy - simply tap into your existing 3rd brake light wire and install with the provided hardware. At just $68.94, this inexpensive mod is perfect for upgraded functionality...your trail partner can spot you a half-mile ahead!
(NOTE: Only red can be used as a 3rd brake light. The ColorSHIFT model can be tied into existing wheel ring wiring for power.)
Universal Fitment
Mounting Hardware Included.
Warranty Period: 1 Year
Product Includes:
• (1) x Aluminum Wheel Ring equipped with Premium ORACLE LEDs
• (3) x Aluminum Mounting Brackets.
• Screws, Zip-ties, and T-Taps
GET YOURS HERE
Option #2: JL "Smoked Lens" LED 3rd Brake Light
New product alert! Add a more aggressive look to your Jeep Wrangler JL with this dark tinted lens LED High-Mount 3rd Brake Light. Featuring bright red LEDs, this gives an updated look to the halogen original part. A direct-replacement part, the wiring is easy with a “Plug and Play” connection to the factory cable connector without any error codes. Install is easy: just remove the original light (2 screws) and install this in its place. Just $69.95, this is another great option for an upgrade.
Works with Spare Tire or with Spare Tire delete relocation.
Installation Time: 5 Min
Lens Material: PMMA
GET YOURS HERE
