Kata
I meant to call Mopar and ask them. I’ll try and remember to call tomorrow.Probably.
Nice looking JLUR. How much does your rims and tires weigh?Here’s before and after Mopar lift. 35/12.50 on 20x12 rims. Didn’t have any rubbing daily driving, did rub wheeling however.
I asked because I’ve been told that there is a weight limit and if you’re over that limit you could created undo stress to your axles and other powertrain hardware. Correct me if I’m wrong. I’m new to the Jeep world and trying to figure things.Thanks... Never weighed them but, judging by when I was putting the spare on carrier, I’d say 75 lbs give or take.
I’m not sure about that, haven’t heard anything,but the rubicon advertises you can run 35s without a lift. So they anticipated people doing that, that’s why the higher fenders and more wheel clearance. Plus it has the Dana 44 axle in front and rear. I know guys running 37s and 38s on these axles without issues. But thanks for the info, I’ll look into it just to make sure.I asked because I’ve been told that there is a weight limit and if you’re over that limit you could created undo stress to your axles and other powertrain hardware. Correct me if I’m wrong. I’m new to the Jeep world and trying to figure things.
Nice rig, looks like you got more than 2” with lift like I didMopar 2" Lift with 20" Wheels 35" tires, I love it!
2.5 EVO lift with 18 and 35x12.5I was curious if you went with a larger rim' say 18inch. How would that look with 35s and the mopar lift?
BBDOC,Check out the Dynatrac 2” Endurosport lift. It’s perfect for 35”s on a Rubi JLU. I love mine! Can try to post some good before and after pics in the same position tomorrow.
Nice setup. Loving the Lift, the Rims, and the Tires. What is the width of the rims, what is offset, and can you take a photo of the how the tires extend from the fenders? Thanks.Mopar 2" Lift with 20" Wheels 35" tires, I love it!
35 KO2s on Teraflex 1.5 St1 with Falcon shocks went on today. It's a little taller in the fender but I'm happy with the ride quality. i also plan on eventually putting on a roof rack, some overland gear, etc. so the added weight will probably reduce the height a bit. not going to 37s unless absolutely necessary.
Will try to post some pics tomorrow.
Before and after 2” Endurosport lift by Dynatrac.BBDOC,
Please do...looking for a very small lift for 35s.
Kevin
I have the OEM metal bumper and yes they will but they do rub slightly on the bumper..Does anyone know if a 35 inch tire (KO2) will fit on the spare tire rack on the back? If not what do you suggest I do to have it fit?
I have a sport a btw. Idk if that matters.
