OldGuyNewJeep
Reposting from 2-door thread (247412, 249190)...
There are handles on top of the front seats (next to the headrests) that rear passengers use to flip 'n roll the seats forward for entry/exit.
Anyway, my daughter yanked the passenger side one way too hard, thinking she was meant to pull the seat forward by the handle. It was literally her 1st attempt at using it, and she didn't know that you just need to pull it until the latch lets go, and then after that push on the back of the seat to flip 'n roll. The handle pulls a release cable, and there is a spring mechanism that returns the handle to the closed/flush position. That spring mechansim popped out of the plastic channel holding it in place so that the handle was floppy and not wanting to lay flat (it still worked for releasing the seat).
I eventually got it back how it's supposed to be, but it was a bitch. No room and the spring is sharp.
So, watch your passengers and help them if they don't understand how to climb in. 2-door vehicles are so rare nowadays, I wouldn't expect without some gray hair to know what to do. (I also tried climbing in the back via the driver's side just to see what it's like. Ha! Thank the Flying Spaghetti Monster that it's my Jeep and I'll never have to do that, again!)
UPDATE:
Argh. The spring keeps popping out of the channel. It's ever so slightly bent, which may or may not be the cause. I say may or may not because the whole spring has some side-to-side play that is contributing.
I have zero faith that a dealership tech would do anything else but pop the thing back in the channel, pull the handle a couple of times, and call it a day. That's what I did the first two times...
So, I decided to close-off the channel to prevent the spring from escaping. I put a tiny dab of Marine-Tex over the channel to, hopefully, prevent the thing from popping back out. If it breaks through, I think I'll give up and live with a floppy handle. Frustrating, but I'm being careful to only vent to you guys because my daughter felt awful when she did it (literally 2 minutes after I arrived home from the dealership).
UPDATE:
