2 Door Rubicon vs Sport S
Armycop
Jay
Yelm, WA
2012 JK Wrangler, 2010 Camaro SS, 2017 Passat R-Line
Sure anything is possible, just recall seeing earlier in the week or so reference that the JL Sport wouldn’t accommodate 33” without mods.
If you wanted to fit 33s no lift for normal road driving there would not be too much rubbing. The air dam can be trimmed. With some wider tires, they could rub on other suspension parts with factory rims. You can adjust the steering stops or add Spidertrax 1.5 in spacers that push the wheels out or get aftermarket wheels with 4.5-5" of backspacing (factory was 6.25"). If you didn't disconnect your sway bars you were fine. On the trail disconnected you may rub the fenders. That's where a cheap Daystar coil .75" spacer kit can get you a bit higher for clearance. It was only $40 for the JK. I ran the Daystar .75" spacers on top of 2" Rustys springs and had plenty of room for 35s on all 3 of my JKs.
ThirtyOne
Rock Sponsor (Level 1)
Chapel Hill, NC
www.jeepdoodles.com
Jeepster2018
Jeepster2018
Mid Atlantic US
VW GTI
Exactly...would require some kind of modifications...
Done Right LED
