2-Door Rubicon taller than my JLUR??
Megsxr750
Iowa
2001 Gsxr750 ,2014 Mazda6,and a 2018 JLUR Sting-Gray
I stopped by my dealer lot and saw this 2-Door Sting-Gray Rubicon and pulled up next to it, seems it sits a little higher than mine?? Anyone else notice this with theirs?? Both vehicles were parked on a small incline, tried both sides. I wish both would have been on flat ground. Not sure if it is just the angle??
Megsxr750
Megsxr750
Iowa
All stock from what I could tell, red rubicon shocks, no fox shocks. Same tires.
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
Yours has probably settled a bit as well as 4 doors carry more weight. Also, new ones only have 4 - 5 gallons in the tank or less.
BillG
Bill
Middle Tennessee
2018 Sting Gray JLUR / 15 Harley Tri glide / 50 Dodge Rat pickup
Seek help. Sounds like you have some sort of complex.;)
MACCTM
Phoenix, AZ
2018 JLU, Honda Fury motorcycle, Infiniti QX30
Steel bumper and stinger.
The_Phew
'17 GTI 6MT
It's not like a lift is universally better; on-road you get more fuel consumption and worse handling, and off-road you are more prone to rollover. On most of the hillside trails around me, you'd rather have a lower center of gravity than better approach/departure angles.
SubZero_JL
Kansas
2018 Jeep Wrangler Unlimited Sport S
Military
I have the same issue! I have a 2-door JLU Sport S and the 2" Mopar lift was installed by the dealer. I was at my local 4WP shop and they had a customer who had the same model as mine who got the same 2" lift. His set higher than mine and the only thing I could think of why is he had a set of Goodyear 35/12.50R17 MT and I have a set of Pro-comp AT Sport 315/70R16. Not I know mostly these tires are same size but what do you guys think? I uploaded some pictures as well.
SubZero_JL
Kansas
Military
I would not let upload pictures!
UKCATS
DFW
2020 JLUR Recon/2020 Mazda3 Hatchback
I play piano in a whorehouse
‘Cause, two doors are betterer.
DaltonGang
Houston, Tx
That 2 dr sits nicely. I doubt the different bumpers account for the added height. More than likely, different springs. Only one way to see, crawl under and look at the tag on them.
Clayton Offroad
