2 door owners, what tire size you running? Pics?
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
This is a really poorly formed question. It should have been what tires, lift and other mods, and do you wheel hard?
I'm running just what the JL 2dr RUBICON was designed for--
---315/75Rx16-(35") HANKOOK DYNAPRO MT tires
JIMBO
No way you can wheel hard on that tire stock. My JLR stock barely has any room
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? 2022-05-21 13.25.10
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? 2022-05-21 13.25.31
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? 2022-05-21 13.25.51
I'm asking because I've found a screaming deal on really nice beadlocks with Toyo 33x12.50x17 off a JK. I'm guessing they'll rub and I don't want to modify my JLR because I'm selling it and ordering a JLUR that will be lifted.
I'm running 35's.
mods? Mall crawler?
35/12.5/17
315/70/17, no lift
no lift and no rock crawling?
37's on 17" Beadlocks
Very nice, obviously lifted and you wheel.
295/70/17 on 17x8.5 +10 No Lift
Rubbing when you wheel?
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? 2022-05-21 13.25.21
blnewt
New Mexico
Just ask @cosine he knows!
Did rub a little bit when I ran Rocky Gap, just the upper area of inner front fender liners at full stuff, I've since added 1" puck bump stops in the front, will be running 315/70/17s soon, so might have to add a bit more stop, I'll probably run it as-is and see though :)
Here's the trail and how my Jeep is setup now (and that's how it was for that trail). Having those high fenders helps a lot, I think with your wider Rubicon axles and higher Rubicon fenders should allow full flex on the 33x12.5x17 tires.
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? Snapchat-704580492
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? IMG_0899.JPG
BuyHold
Tim
Washington
'84 Gr.Wagoneer, '98 TJ, '21 2-Dr Rubi
I wheel medium. That means taking it to local trails but I try to avoid body damage.
Have a 2DOOR JLR. Experience is OEM33s/no lift->35x11.5/no lift->35x11.5/1.5inch lift->35x11.5/2.0inch lift.
On OEM Rubicon rims no lift, 35sx11.5s are fine. I had the slightest kiss on the rear fender liners and since I only go slow when at full flex, it is no problem.
Impromptu pic on current 35x11.5s and the 2.0inch lift. Full flex on as I was coming down a steep drop. Was barely rubbing (2 inch lift but bumpstops have squish that give little more).
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? 82DB824C-B259-43D7-A59F-B4BC5E974A12_1_105_c
Opus
Midwest US
www.jlwranglerforums.com
2023 Sport S, 2021 Compass
Stock 245s...
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? IMG_1600
Don't see a need to go bigger, just maybe an A/T tire once the Michelins are worn out.
16JLR
AL
2016 Rubicon
35s no lift, but aftermarket fenders. How it was when I bought it.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR 2dr
Stock 245s...
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? IMG_6077
Bigger rocks? My stocks were 285 and now very happy with 315s doing some rock crawling.
MattT69
Matthew
Utah
Jeep Wrangler JL Rubicon
37s KO2 -12offset with 2.5 danatrac lift.
Jeep Wrangler JL 2 door owners, what tire size you running? Pics? Jeep In UT
